help, no spark.
Old Jan 1, 2006 | 04:09 PM
whoneedzvtec's Avatar
Default help, no spark.
hey guys, i have a b18a ob2 integra with aem ems and stock ignition system. the problem i am having is, there is no spark only while trying to start the car. the spark is'nt completly gone but u kinda have to get lucky to get it started and it takes a very long time of trying to get it to start. once it is started, the car runs flawless, no miss firing or anything like that. i've tryed new spark plugs, new cap and rotor, new wires, new distributor,and also we tryed checking with a volt meter to make sure the aem is getting a signal and it is. can anybody think of anything else? thanks in advance.
Old Jan 1, 2006 | 05:04 PM
blkb18's Avatar
Default Re: help, no spark. (whoneedzvtec)
check for a weak coil, possibly a igniter going bad?
Old Jan 1, 2006 | 05:52 PM
Default Re: help, no spark. (blkb18)
i have already tried to put a new distributor in the the car, it does the same thing. but thank you. any other ideas?
Old Jan 1, 2006 | 11:31 PM
ttt for some smart peeps to see this thread
Old Jan 2, 2006 | 06:23 AM
danerr's Avatar
make sure your coil is getting proper power with a voltmeter, ive also had problems where loose wire connectors cause intermittent failure.
ignition: ecu > igniter > coil > distributor.
when i had no-spark problems, i hooked up an led to verify the ecu is sending the ignition pulse, this was very helpful. the ecu SHOULD be sending that ignition pulse while you are cranking the engine. looks like this is going to be a process of elimination.
Old Jan 2, 2006 | 09:49 AM
Default Re: (danerr)
definetly a process of elimination, thanks for the help, i will definetly try what u said. any other ideas?
Old Jan 2, 2006 | 06:20 PM
QuangAlang's Avatar
yeah my friend's eg is doing the same thing. after he shuts off his car it wont start up again sometimes, then it would start after like 5 minutes of waiting. he has good spark and good timing. i told him it was a fuel problem and proved it to him by pouring a bit of gas in the cylinders and it starts right up and runs smooth like theres no problem no misfire or anything. he's been pouring gas in the cylinders to start it now for about a week now .... try checking your fuel system.....
Old Jan 2, 2006 | 06:45 PM
Default Re: (QuangAlang)
yea. i have an aem ems and trust me i have sat there for hours on in changing start up fuel, start timing, injector sizes, warmup enrichment tables, and god knows what else. its definetly a ignition problem, but hey thanks for ur help though man.
Old Jan 5, 2006 | 05:20 PM
danerr's Avatar
Default Re: (whoneedzvtec)
hey dude if ur good with wires and troubleshooting i can hook up any info u need for ur car. i have alldata and mitchell.
Old Jan 5, 2006 | 07:20 PM
rev-speed's Avatar
plug ur stock ecu back in
if it starts fine its the aem..(im thinking it has a bad program)
im sure u tried spraying carb clean while starting to eliminate fuel problems rite
Old Jan 5, 2006 | 09:45 PM
amckee's Avatar
Check for consistant voltage to the ignitor, Your relay could be intermittant under a load and check all of your grounds.
Old Jan 7, 2006 | 10:47 PM
BIGGINS LS-VTEC's Avatar
Default Re: (amckee)
are you sure its not a fuel problem ? and check to be sure its a good cool leave the key on and jump the positive side of the coil to the negitive and you should get a spark out of it if you dont theres a problem with the wires that run to the coil or there is a problwm wiht the coil
Old Jan 8, 2006 | 01:24 AM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">Check for consistant voltage to the ignitor, Your relay could be intermittant under a load and check all of your grounds.</TD></TR></TABLE>
if i where you i wouldnt be checking voltage on your secondarys lol
Old Jan 8, 2006 | 04:50 AM
amckee's Avatar
Default Re: (BaNAnABoAt689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaNAnABoAt689 &raquo;</TD></TR><TR><TD CLASS="quote">
if i where you i wouldnt be checking voltage on your secondarys lol</TD></TR></TABLE>The ignitor is not the secondary and he's reading for 12 volts. The big voltage comes from the coil after the ignitor tells it what to do. LOL at yourself bananahead.
Old Jan 8, 2006 | 09:36 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">The ignitor is not the secondary and he's reading for 12 volts. The big voltage comes from the coil after the ignitor tells it what to do. LOL at yourself bananahead.</TD></TR></TABLE>
sorry i was confusing you ignitor with the rotor... so mean with the words, what ever happen to that honda-tech love...
egcoupe918
48
Dec 20, 2012 02:16 PM
hey man
Dec 22, 2010 06:59 AM
egluism33
May 25, 2008 06:17 PM
keng
Jul 6, 2005 07:27 AM
