help: quick injector question
Old Jan 8, 2006 | 07:52 PM
na96civic's Avatar
Default help: quick injector question
okay. im doin dpfi to mpfi and using obd1 injectors. for each injector, if one wire goes to the ecu...is the other one ground? cause im also wondering if it would be safe if i grounded all four wires.
Old Jan 8, 2006 | 09:05 PM
Relic1's Avatar
I know for sure that with the OBD1 versions of the P72/P30/P28/P08/P07/P06/P05 the other side of the injectors run to 12Volts at the drivers shock tower through a group of yellow/black wires.
I'm pretty sure that all honda ECUs are wired that way, but I'm not 100%
Old Jan 9, 2006 | 02:13 PM
Perfectionist's Avatar
Default Re: help: quick injector question (na96civic)
The injectors get their power from the main relay through the injector resistors. That's the yellow/black wires. The ECU grounds the injectors to trigger them. Do not ground any of them yourself.
Old Jan 9, 2006 | 03:21 PM
na96civic's Avatar
Default Re: help: quick injector question (Perfectionist)
cool. thanx for the info
88 EF Hatch
Sep 24, 2009 10:59 AM
efjones9
12
Feb 10, 2009 09:44 AM
turbo_ef9
Jan 24, 2005 09:47 AM
Audipwr1
Jun 4, 2003 07:03 AM
EGHatchy
Jul 13, 2002 08:53 AM
