firewall MAP sensor
Old Jan 7, 2006 | 09:51 AM
92eg6_pino's Avatar
Default firewall MAP sensor
sorry for dis noob question....i just had my engine swapped and is throwin out a map sensor code. can i use my old map sensor(d15b single cam) and put it on my jdm b16?but on the old 1 it was on the IM and some ppl told me if not on the IM it will be on the firewall. how do i do that?can somebody tell me the instructions on how to connect it??do i have to drill a hole?
Old Jan 7, 2006 | 05:33 PM
biotech0123's Avatar
Default Re: firewall MAP sensor (92eg6_pino)
Does the throttle body not have a location at the top to where it can be mounted, if not then you will need the one that goes on the firewall with a #7 vac line. Simple wiring if you can read and understand a schematic.. Hope this helps some
ALL MOTOR DA
Jun 8, 2006 02:35 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
SVOboy
Mar 26, 2006 11:48 AM
88crxhfb16
Apr 16, 2005 05:59 PM
