vafc help
Old Jan 1, 2006 | 12:53 PM
WTR's Avatar
WTR
Default vafc help
I got a vafc 1 and i installed it on a eg civic.The problem is that the car is pulling a map sensor code with this thinng hooked up.I checked the wiring 3 times and it is correct.When you unhook the pressure wires the car runs fine.anyone got any ideas why this might happen. thanks
Old Jan 1, 2006 | 04:35 PM
EE_Chris's Avatar
Default Re: vafc help (WTR)
Did you set up the parameters correctly and go through the initialization described in the user manual?
After the VAFC has been initialized, it's effectively 0'd out which means MAP output should eqaul MAP input - as if the VAFC isn't even there.
So if you disconnect the MAP wires and hook them back up to one another and get no code, then either your wiring is wrong, the VAFC is bad or you didn't set it up properly.
Old Jan 2, 2006 | 09:02 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: vafc help (EE_Chris)
I would also bet that the setup was incorrect. There are a number of setup parameters that you have to set (as you probably know) for your car. Check those again.
Slow_import
11
Jan 29, 2010 05:26 PM
South Bay Surfer
Dec 24, 2004 02:15 PM
PrecisionH23a
Sep 17, 2002 10:24 AM
2000blacksi
Aug 27, 2002 10:28 AM
