click noise in distributor
Old Jan 6, 2006 | 10:04 PM
bleedblue94's Avatar
Default click noise in distributor
well i went to check my distribyutor the other day bc ive been have some idle problems and when i took the cap off i found that the screw that holds the rotor on had come off and was resting inside.....so i went and put the screw back in with some locktite and when i went to go start the car again a now hear a clicking sound coming from inside the dizzy. the noise was not there before , but now it sounds simalar to the clicking you can hear when you listen to injectors......anyone have any idea what this could be?
Old Jan 7, 2006 | 06:18 AM
99CivicSiBrian's Avatar
B A N N E D
Default Re: click noise in distributor (bleedblue94)
I would change the cap and rotor. I suppose it's possible that the screw was bouncing around in there, and of course that wouldn't be good.
B
Old Jan 7, 2006 | 08:14 AM
Default Re: click noise in distributor (99CivicSiBrian)
alright i changed the cap and rotor and i still have the clicking noise....any other ideas
Old Jan 7, 2006 | 12:31 PM
ttt
Old Jan 7, 2006 | 12:57 PM
B A N N E D
hmmm. . . how much play is there in the 'shaft'? it's possible there's something wrong there too. . .
B
Old Jan 7, 2006 | 01:15 PM
no play in the shaft....when i get out of work im going to take it off and take the whole thing apart
Old Jan 7, 2006 | 01:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The bearing inside is probably going out..
The heat generated from the bearing failure ususally
is the cause of the srew coming out..
Was there a dark red dust inside the cap?
You can usually find the bearing at NAPA if
you can find someone to look it up in the catalog
by the actual size..
#6001-2ZJ is the number I used for a B16 unit...
Edited to repair links:
http://www.angelfire.com/ca/Dr....html
http://www3.honda-perf.org/com...r.htm
Modified by 88DXCRX at 1:40 PM 1/8/2006
Old Jan 7, 2006 | 02:02 PM
Default Re: click noise in distributor (88DXCRX)
i appreciate the help....but there is not dust inside and the noise that im hearing is not a bearing noise
Old Jan 7, 2006 | 10:08 PM
B A N N E D
check the shaft that the rotor is attached to for play by simply wiggling it in and out and back and forth. There will be a slight amount of rotational play.
Also, is that mystical 'cover' inside the distributor making contact with the rotor maybe? It'd be weird but possible I suppose.
B
Tasp72
Feb 16, 2016 04:50 PM
b.d.racing
Mar 4, 2008 04:44 PM
munscher
Apr 10, 2005 07:25 PM
TheIntegraGuy
Apr 18, 2003 08:31 AM
Todd00
10
Jun 25, 2002 07:28 AM
