Yep a new tps problem... maybe not tps.. funny problem...
Old Dec 29, 2005 | 09:12 PM
guywitaDA's Avatar
Default Yep a new tps problem... maybe not tps.. funny problem...
I have a 92 gsr.. with a ls/v and the car kinda sputters at idle and it idles really low.. around 200-400 rpm.. and there is no way to adjust the throttle.. i have the idle screw all the way out and it still wont ilde up...... and when u are driving down the highway and barily press the throttle the car sputters and cuts back... but if i hit full throttle it runs fine.... ok here is the wierd part .... if i unplug the tps it runs perfect..even idles perfect. but of course it throws a light.. so i replaced the tps with three diff sensors.... and it still does the samething any ideas im stumped.. checked voltage and its around 4.5 at open throttle
Old Dec 29, 2005 | 10:13 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Yep a new tps problem... maybe not tps.. funny problem... (guywitaDA)
What are your specs? It almost sounds like your running super rich, but Im not sure.
Old Dec 29, 2005 | 10:24 PM
guywitaDA's Avatar
Default Re: Yep a new tps problem... maybe not tps.. funny problem... (JDM_Ej)
well i have a phearable tuned ecu.... but how would that explain the reason it runs good when i unplug the tps...?????
import-tooner
Jul 19, 2013 06:39 AM
N2O INTEGRA
Sep 14, 2007 12:03 PM
JasonST
Feb 15, 2007 07:02 PM
Jeef
May 3, 2005 07:01 AM
SIK IN DA HED
Dec 24, 2002 06:06 AM
