just got back from smog i have a quick question..
Old Jan 4, 2006 | 02:22 PM
xx89civicracer89xx's Avatar
Default just got back from smog i have a quick question..
Ok well i just got a 90 civic dx like a month ago and the deal was i was going to smog it.. well i just did today i did a pretest for 20 buxs here and it falled.. one this it said is modified PCV valve... so i looked at that and i changed the tube on it because i saw it was ripped right where it conects on the valve.. i also just replaced the valve to...well it failed in the NOX area everything else is fin and it only failed in the 15MPH section well here are the numbers
NOX(PPM)
MAX AVE MEAS
835 237 894
well let me know what u think it is.. i did change the oil about 1 month ago and i did a thing called engine flush then.. so im thinking maybe do another oil change right now and then but that NO SMOKE addative in my oil and it should fix my problem>? well
Old Jan 4, 2006 | 08:49 PM
dfoxengr's Avatar
Default Re: just got back from smog i have a quick question.. (xx89civicracer89xx)
retard your distributor timing, and get some "guaranteed to pass" or the like from NAPA.
keep the car at operating temps before you get the test done...
Old Jan 5, 2006 | 07:41 AM
suspendedHatch's Avatar
Never use any oil additives.
Except maybe for an oil flush ie Seafoam since you only run the car for a few miles and then change it out anyway.
Like he said, retard the timing and maybe use a higher octane. Your motor is running hot.
Old Jan 5, 2006 | 09:43 AM
rev-speed's Avatar
u need to post up ur smog test vir
4 us to help u
all 4 gases r related to each other.....
and no ur oil change with the addative didn t hurt emmission.........
Old Jan 5, 2006 | 12:57 PM
Default Re: (rev-speed)
alright in a little bit ill post all of my ratings... thanks
Old Jan 9, 2006 | 11:18 PM
TEST ONLY's Avatar
89civic racer: If you have any smog related questions, eail me.
wardseg6
Sep 15, 2016 08:52 AM
champLSinteg
Oct 3, 2007 07:04 AM
acura_9485
Sep 14, 2005 11:46 PM
teggytegteg
May 27, 2005 11:01 PM
