HOT plugs OK in HIGH C/R engine?
Old May 14, 2002 | 08:30 AM
HumanResource's Avatar
Default HOT plugs OK in HIGH C/R engine?
OK I ran into a guy on this board who was running High C/R pistons (12.0). He Hasn't had a smog check yet, BUT some guys including me use the NGK extended reach HOT plugs (part number NGK ZFR4F-11) with lower FP to pass. Is it possible to rund these plugs with the High C/R. I would think there might be a problem, but I wanna hear from you guys. Thanks!
Old May 14, 2002 | 08:58 AM
Rocket's Avatar
Default Re: HOT plugs OK in HIGH C/R engine? (Chris90STD)
It depends on how much heat(power) you are going to put on the plugs. If you driving in stop and go traffic all the time it's not a problem. If you plan to break the land speed record then you are going to have major problems.
Old May 14, 2002 | 09:00 AM
integra0260's Avatar
New User
Default Re: HOT plugs OK in HIGH C/R engine? (Rocket)
LMAO
Old May 14, 2002 | 09:31 AM
No Land Speed records here, just install warm run for 15-20 min then R&R.
Old May 14, 2002 | 09:35 AM
Rocket's Avatar
You're cool then. The ZFR4F-11 are used on I think the HF motors so if you limit the power you are using to say 60 hp then you are coo.
Old May 14, 2002 | 12:49 PM
JDM_DOHC_SiR's Avatar
New User
Right now I'm Running 13.5:1 C/R with HKS S30i's in the winter and S35i's in the summer...S30i's are #6 and S35i's are #7 ...not a single problem
StockAccord
12
Aug 24, 2009 09:53 AM
TravisCadello
14
Feb 4, 2009 11:41 AM
mrx
Aug 24, 2005 02:32 AM
skierGT
Jun 17, 2003 05:06 AM
DamnSlowCivic
Apr 15, 2002 07:29 AM
