ls/vtec
Old May 14, 2002 | 02:24 PM
DLB1994's Avatar
Default ls/vtec
How much hp u think a stock ls/vtec will make?
b18a block b16a1 head
stock b18a pistons
How much can i mill a b16a head?
What can i do to up the comp with out putting pistons in?
Old May 14, 2002 | 02:43 PM
InfamousRS's Avatar
Default Re: ls/vtec (DLB1994)
My b16 head is milled .020. It will make the CR ~10.1:1. I will be putting my setup together this coming weekend.
If you would like to see my setup, go here https://honda-tech.com/zerothread?id=185733
I have no Idea how much power it will make though.
Old May 15, 2002 | 08:31 AM
DLB1994's Avatar
Default Re: ls/vtec (InfamousRS)
what do i got to do to put pr3 pistons in
Old May 15, 2002 | 11:42 AM
kinesistech's Avatar
With ls pistons, your compression will be 9.5 before you mill the head. With b16 pistons, 11.3. All you have to do is put the pistons on the ls rods.
If your all motor you need the b16 pistons or your enigne is weak.
HondaBurger
Sep 19, 2007 02:36 PM
1995sir
Apr 26, 2006 07:43 PM
botlebruiser
Mar 14, 2006 05:04 PM
stockb16hatch
30
Feb 21, 2006 12:42 PM
yellowcivic
Mar 15, 2002 10:57 AM
