AC question
Old May 9, 2002 | 11:54 AM
nixadm's Avatar
Default AC question
I have a 96 civic dx, it's ran fine for 60k miles or so, but now the ac is screeching when i hit rpm above 3-4 with ac on. I was told my compressor is going out, then someone else told me I need to add oil to my compressor (never heard of this).
Anyone have info? thanks
Old May 9, 2002 | 03:40 PM
Honda4CX-T's Avatar
Default Re: AC question (nixadm)
It's called "Mineral Oil" for your A/C compressor. And yes you could be low if you have a small leak or if you do not cycle your A/C often (winters if u know wht I'm talking about).
BTW, it smells like crap when you open a bottle of this stuff.
Old May 9, 2002 | 04:33 PM
Chiovnidca's Avatar
Default Re: AC question (Honda4CX-R)
No, no, no. Don't use mineral oil. A "96" has a 134a system that uses PAG oil. BTW, thats probably not the problem. A weak compressor clutch will cause a screeching noise when it slips.
Old May 9, 2002 | 06:13 PM
khoalie's Avatar
Default Re: AC question (Chiovnidca)
mine did that
try tightening the belt
worked for me
Old May 9, 2002 | 06:21 PM
BreakStuff's Avatar
New User
Default Re: AC question (khoalie)
yippers... sounds like a loose belt.. if it were a bad compressor/clutch assy then it would squeek whenever the a/c was in use..
Old May 10, 2002 | 05:22 AM
Honda4CX-T's Avatar
....... My mistake that's what I mean PAG Oil
Old May 10, 2002 | 07:48 AM
nixadm's Avatar
Thanks guy's i'll try the belt. now that I think about it, its probably the belt, about 40,000 miles ago the timing belt (i think, it runs the ac and all that) split in half, so i cut half of it off and been running on a half a belt for awhile, eheh
Old May 10, 2002 | 08:02 AM
integRated109's Avatar
bad idea man......if that belt snaps you have some serious head and valve damage......might want to get that fixed
Old May 10, 2002 | 08:06 AM
nixadm's Avatar
yeh? I had a 92 civic that the whole wheel the belt sits on broke off and parts were falling under my car driving down the road.
flaveNico
Honda Accord (2013 - 2015)
Jul 19, 2018 02:03 PM
Zebra
Honda Civic (2006 - 2015)
Feb 8, 2018 08:21 PM
Rick1t
May 6, 2013 06:03 PM
JohnnyEF
Jul 28, 2009 08:02 AM
nwf_snake
Apr 8, 2008 08:41 AM
