ITR CRX swap??? Need help BAD!!!!!
Old May 14, 2002 | 02:24 AM
ITB rules's Avatar
Default ITR CRX swap??? Need help BAD!!!!!
ok here is the problem guys, please help.
91 CRX SI
00 ITR long block, old school b16a Dist. and alternator. YS1 LSD cable tranny. PR3 spoon ECU.
knock sensor wire and vtec wires are all wire up correctly.
Cut old school b16a injector plugs, wire it back up into the OBD2 ITR plugs to work with the OBD2 ITR injectors.
The car starts up everything, no check engine light. But it doesn't run right, it idles like its low on fuel? what do you guys think???
Or can someone tell me the correct way to do this swap?
Old May 14, 2002 | 07:11 AM
rainforest's Avatar
Default Re: ITR CRX swap??? Need help BAD!!!!! (ITB rules)
check out the fuel maps on the spoon ecu you might not be getting enough fuel at idle, how does it run after idle.
Old May 14, 2002 | 01:00 PM
ITB rules's Avatar
Default Re: ITR CRX swap??? Need help BAD!!!!! (myotherrideisyourbitch)
thank you for all the replys guys, the problem has solve. it was a bad dist.
BTW i'm still running the OBD2 injectors, i believe they are the same thing with the 91 Si
thank you
Greg
Old May 14, 2002 | 02:00 PM
Sonny's Avatar
The obd 2 injectors have diffrent resistance then obd1 injectors so you will need to run obd 1 injectors
No...that is wrong!
Sonny
Old May 14, 2002 | 06:42 PM
ITB rules's Avatar
Default Re: ITR CRX swap??? Need help BAD!!!!! (Sonny)
aren't they all 240s?
Old May 14, 2002 | 06:49 PM
1 2 NV's Avatar
he means resistance, measured in ohms. my injectors ohm out at 16.
Old May 14, 2002 | 06:59 PM
BoM's Avatar
BoM
Default Re: ITR CRX swap??? Need help BAD!!!!! (hondaatwsu)
u might need a new fuel.
GSRinmyCRX
13
Jul 21, 2010 02:26 PM
i.love.my.cx.hatch
Mar 2, 2009 03:25 PM
UnspokenTruth
Jun 8, 2004 09:16 PM
Yell88CRXsi
Nov 10, 2002 06:10 PM
ITB rules
May 15, 2002 09:21 PM
