Code "2" on a 94-95 gsr ecu!!!
Old May 9, 2002 | 10:36 PM
4drlsvtec's Avatar
Default Code "2" on a 94-95 gsr ecu!!!
I know that this code indicates 2nd 02 sensor... But 94-95 GSR's don't have a 2nd 02....
Could the Ecu be bad...
Thanks,Doug
Old May 10, 2002 | 01:34 AM
Kamin's Avatar
Default Re: Code "2" on a 94-95 gsr ecu!!! (4drlsvtec)
i dont think its a 94-95 gsr ecu then
you shouldnt be throwing that code (every listing i have is for civics but um its obdI i dont think the gsr ecu is diffrent)
reset your ecu (unplug battery negative cable for at least 15 seconds)
look o the bar code of the ecu, whats the number? (p30, 038)
Old May 10, 2002 | 03:37 PM
jdm-spec-eg's Avatar
trust me, this code exists in this computer. i had a 94-95 OBD1 GSR ecu and it would give me code 2. I couldnt figure it out so I sold it. But the guy I sold it to said it never did it to him.
Old May 10, 2002 | 03:48 PM
Kamin's Avatar
Default Re: Code "2" on a 94-95 gsr ecu!!! (jdm-spec-eg)
i would check your o2 sensor then.
replace it with one that works and see if it goes away
might want to swap ecu's too
just an idea.
[Modified by KAMiN, 4:50 PM 5/10/2002]
Old May 10, 2002 | 03:51 PM
Default Re: Code "2" on a 94-95 gsr ecu!!! (KAMiN)
I have the 95 Integra manual from Acura, but there is no listing for code 2. I have yet to figure this out. Atleast I feel some what sane now that someone else has the same problem! I put in a different ecu, and that code never came back!!
thunderboy
Apr 25, 2010 02:17 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
Mires
Jul 10, 2003 10:15 AM
