Camshaft lubricant
Old Jan 25, 2003 | 11:38 AM
Malgerus's Avatar
Default Camshaft lubricant
Is Federal Mogul's "Assembly Lubricant" the right stuff to use on the lobes and journals of the cams? My manual says I need camshaft lubricant. I'm changing the cam seals on my B16A. Please help
Old Jan 25, 2003 | 11:45 AM
delslow94's Avatar
Default Re: Camshaft lubricant (Mr. S)
usually any assembly lube will be ok. just make sure if you have titanium retainers to not use lube with graphite in it. supposedly it etches the retainers. how much of this is tru im not sure, i found this out too late but no damage to date so i guess its ok.
Old Jan 25, 2003 | 11:57 AM
Malgerus's Avatar
Default Re: Camshaft lubricant (delslow94)
No I don't have titanium retainers, the B16A is completely stock. It should be ok then? It's probably better than nothing, right My brother didn't use any when he did is.
callmetree19
Dec 20, 2008 06:02 PM
1SikEagle
Oct 18, 2008 02:34 PM
FerioRallyB16a
Apr 19, 2007 03:07 PM
zman
Aug 5, 2004 09:50 AM
bluecal
Feb 18, 2004 07:29 PM
