is there a High compression Head gasket for a B20?
Old Jan 27, 2003 | 04:40 PM
. o 69 o .'s Avatar
Default is there a High compression Head gasket for a B20?
??? and if so who makes it? and How much?
Old Jan 27, 2003 | 05:07 PM
Kataku2K3's Avatar
Default Re: is there a High compression Head gasket for a B20? (B16B)
Cometic if you want to do so.... I've had problems with them sealing before but with a little copper spray you should be okay.... They'll normally run ~$90... Good Luck... Also this is just the way i do things and only if money allows but I always just use OE headgaskets... Like I just said in another post I only use Cometic for boosted and big bore motors... Even with an 84.25-84.50mm you can still get away with a stock OE headgasket.... To get the compression up toss in some new pistons.... Again that's just me... Latez
RATED RX-7
13
Mar 25, 2011 04:38 PM
honkyb18c
15
Jun 23, 2009 08:17 AM
donaldmejr
Aug 31, 2008 02:39 PM
BigC-ivic
Mar 19, 2005 07:28 PM
88B20CRX
Jun 24, 2003 10:56 AM
