Autometer water temp guage install
Old Jan 25, 2003 | 07:19 PM
mgast's Avatar
Default Autometer water temp guage install
I am planning on installing an electric autometer water temp guage, and I had a couple of questions. The question is where is the stock sending unit and is all that I have to do is take out the stock one adn replace it with the autometer one? I heard from someone that there is 2 sending units one for your guage and one for your computer and you are just supposed to replace the one for your guage with the autometer one. and yes I already did a search.
thanks in advance
matt
Old Jan 25, 2003 | 07:40 PM
qcoffey's Avatar
Default Re: Autometer water temp guage install (mgast)
I wouldn't take out the stock guage. I installed mine by making an adapter that went in the upper coolant line on the radiator. I got a pipe from home depot and drilled and tapped it, then threaded the sender in. I then cut the hose and installed the unit in between. It works like a charm and my factory guage is still working. AC Autotechnic now sells units you can buy that will work real nice. Some companies like Samco and Spoon Sports also sell hose kits with adapters already in the hoses.
Old Jan 25, 2003 | 07:47 PM
rolow's Avatar
Default Re: Autometer water temp guage install (qcoffey)
the stock sender and any after market one have different threads so you can't replace the factory one.
I have the AC Autotechnic and I think greedy makes one to.
Old Jan 25, 2003 | 08:27 PM
tominos's Avatar
or you could just tap into your stock sender.thats what i did. the sender is located right after the upper radiator hose on the block. it's a sohc d16.
Old Jan 26, 2003 | 11:01 AM
mgast's Avatar
Default Re: Autometer water temp guage install (tominos)
what about for b18?
Old May 14, 2003 | 06:55 AM
Fuster_Cluck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgast &raquo;</TD></TR><TR><TD CLASS="quote">what about for b18c1?</TD></TR></TABLE>
Bump!
Anyone have any pics of the install that can be posted? Thanks!
Old May 14, 2003 | 08:17 AM
IN VTEC's Avatar
Default Re: Autometer water temp guage install (Hybrid93Hatch)
We use the hole for the ECT gauge sending unit. You can either just leave out the ECT gauge sending unit and thread the temperature probe into the head, or you can tee it off and run both probes.
bulldog_RS20
Jul 5, 2005 04:12 AM
S@nt0s
Dec 1, 2003 03:23 PM
Eyewitness
28
Sep 24, 2003 01:06 PM
Chugger
Mar 3, 2003 07:04 PM
HapaHaole
Jan 31, 2002 10:43 AM
