rpm problems...HELP!!
Old Jan 26, 2003 | 10:32 PM
Ek9_6's Avatar
Default rpm problems...HELP!!
i have a 96 cx and at idle or low rpm..the car flucuates...and sometimes turns off..the guy i checked with said something about a E.L.M. (electric load management...could this be the problem or is there another solutions...
Old Jan 27, 2003 | 01:39 AM
BluntMan's Avatar
Default Re: rpm problems...HELP!! (h077b0i99)
The first and easiest thing you could do, and this will actually have great benifits, get a grounding kit. Sometimes idle will fluctuate cuz the head's not grounded well enough.
Old Jan 27, 2003 | 02:27 AM
ninesecrx's Avatar
Default Re: rpm problems...HELP!! (BluntMan)
make sure there isnt a vacum look. Then you can look into the tps sensor, idle air control valve and cold start under the TB are all reasons for a poor idle.
jayscivi
Dec 20, 2011 10:28 AM
stuckinmud
Aug 14, 2009 08:32 AM
BrokenRex
Oct 13, 2005 08:25 PM
rdeezy25
May 17, 2005 01:55 PM
