fuel pump question
Old Jan 27, 2003 | 06:06 PM
hondaeg5's Avatar
Default fuel pump question
i searched and found that stock civic pumps are all 79lph while all dohc pumps are 135lph. does this mean all of us with hybrid civics that kept our stock fuel pumps are running lean? please tell me im wrong.
Old Jan 27, 2003 | 06:21 PM
lazy bum shaughn's Avatar
Default Re: fuel pump question (hondaeg5)
Good question dear.
Bump for you.
Old Jan 27, 2003 | 06:59 PM
slomofo's Avatar
GDD Member
I always thought the fuel pressure regulator fixed that problem.
Old Jan 27, 2003 | 07:01 PM
hondaeg5's Avatar
Default Re: fuel pump question (slomofo)
what if your running a stock fpr?
EDIT:sorry i think i understand what you mean now that i read it again.
is this true?
[Modified by hondaeg5, 11:03 PM 1/27/2003]
Old Jan 27, 2003 | 09:37 PM
Dan1krzysi's Avatar
lol, thats funny and true.....lol
Old Jan 27, 2003 | 09:55 PM
1SlowB16EF's Avatar
fuel PRESSURE regulator... that helps pressure but what about VOLUME ?? a fuel pressure regulator will nott increase volume
Old Jan 28, 2003 | 05:34 AM
JimBlake's Avatar
Default Re: fuel pump question (1SlowB16EF)
The FPR is in the return line back to the tank. It works by adjusting the back-pressure thru itself, so the pressure in the fuel rail is correct. Flow rate is whatever it gets from the pump. If the pump is wrong (too small) then possibly sometimes, the FPR will not be able to close itself off enough. This happens if your injectors use lots of fuel, leaving very little to return to the tank. Then the fuel rail pressure will drop; you'll see that if you use a fuel pressure gauge. I suppose then it would run lean & throw a MIL, too.
Old Jan 28, 2003 | 07:11 AM
hondaeg5's Avatar
Default Re: fuel pump question (JimBlake)
anyone else?
Old Jan 28, 2003 | 07:16 AM
DarkSubRosa's Avatar
i want to know the answer too, although i got lucky and put a fuel pump from a 99-00 Si in my old civic, now I got a 255 pump, but i'd still like to know for future reference.
Old Jan 28, 2003 | 12:41 PM
hondaeg5's Avatar
Default Re: fuel pump question (DarkSubRosa)
champLSinteg
Sep 20, 2006 01:44 PM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
G3NR8
Jun 18, 2004 09:09 AM
Simple
Jun 20, 2003 07:33 AM
Lsos
Jan 16, 2003 11:56 AM
