axle
Old Jan 27, 2003 | 12:13 PM
97ex+zex's Avatar
Default axle
how can you seperate the hub assembly from the lower control arm without a puller?
Old Jan 27, 2003 | 12:15 PM
-Whitey-'s Avatar
Default Re: axle (97ex+zex)
a big hammer seriously hold a small hammer on onse side of the lower control arm(lca) and hit the other side a few good hard times and it will drop down.becarefull not to hit anything but the metal lca you might have to lift it up a little to get the lca to drop down
Old Jan 27, 2003 | 01:57 PM
rotten's Avatar
Just get a ball joint remover ($10 at any hardware store) and use a big hammer--be careful not to rip the rubber on the ball joint. Should take 3-4 decent hits.
Old Jan 27, 2003 | 02:02 PM
Desslok's Avatar
Default Re: axle (rotten)
you can borrow a pitman arm puller from autozone for free.
Old Jan 27, 2003 | 02:06 PM
tilt's Avatar
Default Re: axle (sp)
you can also stick a bar between the lca and knuckle and jump on the rotor until it breaks free.
Old Jan 28, 2003 | 03:48 PM
97ex+zex's Avatar
Default Re: axle (tilt)
tryed the hammer didn't do it this time. used the balljointremover didn't get it, but i did manage to rip the rubber on the balljoint[my mad skills]. pitman arm puller got it in 2 seconds BINGO thanks ya'll for the help.
Old Jan 28, 2003 | 04:36 PM
turbohonda's Avatar
Undo the shock fork and take it out, then take out the cotter key and the 17 mm on the lower ball joint, finally lift the hub up and stick a Craftsman 3/8" drive ratchet handle between the LCA and the hub so that it is perpendicular to the floor. It is kind of a pain to get it in there so it stays but once it is there slam your foot down on the hub and it will come free. If you have a sway bar make sure you have both tires off of the ground so the LCA can move. This is the best way and it is fast once you get used to it, besides you won't split the ball joint boot either.
dumbidea
Aug 20, 2017 07:52 PM
Alcatrax30
Nov 9, 2014 05:38 AM
tree fingers
Feb 18, 2008 10:41 PM
s-tech
Aug 6, 2005 10:30 AM
Vp Special K
17
Jan 6, 2004 02:08 PM
