car smoking help?
Old Jan 27, 2003 | 12:13 PM
MisterHYBRID's Avatar
Default car smoking help?
My car started smoking from the exhaust recently, it's a 94dx and it looks like oil is leaking from right under the head. Could this be causing the white smoke? Possible blown head gasket w/ coolant running in causing white smoke? or bad piston rings? need quick possible diagnoses.
Old Jan 27, 2003 | 12:17 PM
97ex+zex's Avatar
Default Re: car smoking help? (MisterHYBRID)
check the oil and see if there is water in it, then it would be your head gasket. my friend has an accord and it was his valve cover gasket and the o-rings in the cover for the sparkplugs. pull the plugs and see if they, or any are soaked in oil. your lucky if its that than the headgasket.
DRoylflush
11
Apr 10, 2011 02:11 PM
a3k
Jul 26, 2009 10:36 PM
EfpormantypR
May 6, 2009 03:27 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
CBlockDis
Jul 16, 2005 11:55 AM
