air fuel guage not working
Old Jan 24, 2003 | 07:20 PM
JDMCIV95's Avatar
Default air fuel guage not working
i have a jdm b16 in my 95 civ and i cannot get my air fuel guage to work. i have it tied in to the white signal wire on the o2. it dosent scane it just lights up, almost the whole gauge. and its my second guage. could my o2 be shot?
Old Jan 24, 2003 | 08:15 PM
tominos's Avatar
Default Re: air fuel guage not working (JDMCIV95)
do you got the one wire o2? my friends jdm b16 does this also. try switching to 4 wire self heating o2.
Old Jan 25, 2003 | 02:47 PM
delslow94's Avatar
what year b16 do you have. make sure u spliced into the correct wire. u can also splice into the wire near the harness im not sure what wire it is. i think its in the a block of the harness. i had the same problem till i used the correct signal wire
Old Jan 25, 2003 | 04:42 PM
lsvtecvx's Avatar
Default Re: air fuel guage not working (delslow94)
I have mine right by the Ecu, having trouble with it though, my car is a VX
so it originally had the 5 wire linear O2 sensor then I switched to the 4 wire,
and I think that might have something to do with it .
Old Jan 25, 2003 | 04:51 PM
khcivic's Avatar
Default Re: air fuel guage not working (lsvtecvx)
i thought the vx o2 sensor was better because it was a wide band . or am i wrong cause i thought of getting one to read my a/f better
Old Jan 25, 2003 | 06:07 PM
976's Avatar
976
New User
Default Re: air fuel guage not working (khcivic)
Tap the wire onto the d14 ecu wire, find a good groud, and install power into radio fuse! Works great.
EDIT: I sure it's d14 or 15, could someone back me up. Use hybrid garage fourm for the ecu pinout digram if you have have one handy...
[Modified by w00t!, 3:07 AM 1/26/2003]
Old Jan 26, 2003 | 01:08 AM
lsvtecvx's Avatar
Default Re: air fuel guage not working (w00t!)
ya it is D14 , and the VX O2 sensor is better but the only ecu that can control it to
my knowledge is the Vx ecu with cant be chipped so there goes that
[Modified by lsvtecvx, 12:52 AM 1/29/2003]
gsr30035hatch
Mar 1, 2006 05:59 PM
elevatethis
Sep 4, 2003 06:09 PM
r30slick
Jun 20, 2002 06:40 AM
r30slick
Jun 19, 2002 08:04 PM
