Compression Cause a Problem???
Old Jan 27, 2003 | 07:15 PM
hanginlow's Avatar
Default Compression Cause a Problem???
My car is running like crap since i had hondata s200, 550's, and my boost controller in. The car didn't run like this before it went into the shop. The shop told me that my compression was low and they said that the car will run like this until i replace my headgasket because it is too thick. Does this sound like BS?
[Modified by boostedf22, 4:17 AM 1/28/2003]
Old Jan 27, 2003 | 11:53 PM
Unsung's Avatar
Default Re: Compression Cause a Problem??? (Cavypoo)
describe crap? Well its a two, sometimes four door, solid rear axle, nascar like stock wing, drum braked, clip on interior, 108 governed, no mid or high end power, sloppy *** cable shifter, or early shifting auto with 3 overdrive gears, noisy, backfiring, red bowtie covered, geo metro bigger brother, *** magnet, and they most times call it a cavalier! you " ****** clown"
.... ok .... now thats some quality input...
Old Jan 28, 2003 | 03:46 AM
BudaKai's Avatar
Default Re: Compression Cause a Problem??? (boostedf22)
What do you mean here? What set-up are you using. What did they do at the shop? Is it tuned? Is it built?
white2draccord
Apr 28, 2008 03:26 AM
Drizzo
Aug 16, 2005 02:00 PM
simoh
Jun 30, 2003 04:25 PM
hanginlow
Jan 28, 2003 07:49 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
