WHY oversized???
Old Jan 26, 2003 | 05:48 PM
GreenR's Avatar
Default WHY oversized???
Why does the factory make oversized pistons? Are they for factory race engines?
Old Jan 26, 2003 | 05:58 PM
ExospeedAMcrx's Avatar
Default Re: WHY oversized??? (GreenR)
say you blow your motor. either by bad rings, or throw a rod/break rods which may gouge the walls of the cylinders. you shouldnt put the same size pistons in there. even in a basic rebuild. alot of shops dont hone and bore and just stick stock bore pistons in there. it will hold but how accurate can it be. best bet is to bore and hone it out a bit bigger, the same size as the oversized pistons, to get the best seal possible.
cylinder walls may warp or get worn out in some ways after so many miles of driving.
Old Jan 26, 2003 | 06:17 PM
Padronis's Avatar
Default Re: WHY oversized??? (efzero)
so you can straighten the bores on a rebuild yO!
That's the reason you hone. So, yeah.
Old Jan 26, 2003 | 06:21 PM
GreenR's Avatar
Default Re: WHY oversized??? (exospeedAMcrx)
mr_munro
Jan 3, 2011 05:26 PM
rich7777
10
Feb 25, 2010 11:58 AM
giomfe
Nov 19, 2006 09:00 AM
EARLdaSQUIRREL
Apr 5, 2005 07:22 PM
turbo89civicb18hatch
Nov 8, 2004 04:42 PM
