B16 Compression Test
Old Jan 26, 2003 | 10:02 AM
rca90gsx's Avatar
Default B16 Compression Test
Just wondering what are some good results for a compression test on a stock B16a (first gen series) engine? Haven't found much results searching.....
Thanks for your time,
Richie
Old Jan 26, 2003 | 10:12 PM
TimoneX's Avatar
New User
Default Re: B16 Compression Test (rca90gsx)
Compression testers vary quite a bit from one to another. Comparison of one engines #s to anothers with different testers is meaningless. I'd just look for even numbers across the engine. Like +/- 5-10 PSI.
Old Jan 27, 2003 | 05:08 AM
rca90gsx's Avatar
Default Re: B16 Compression Test (TimoneX)
Thanks for the reply. I was mainly (should have stated) looking for the Honda specs for a new engine, I definitely know to look for uneven pressure between cylinders.
Richie
Old Jan 27, 2003 | 06:02 AM
eg6ajk's Avatar
bascially anything above 175psi with spread between the cylinder of under 20psi is acceptable.
few of my motors I have done:
B16A: 215-215-212-210
D15B:210-206-210-209
B18C:240-240-235-234
ZC: 205-200-195-190
honda allows for 28psi spread and lowest reading of 140psi.
Old Jan 27, 2003 | 09:59 AM
rca90gsx's Avatar
Default Re: B16 Compression Test (eg6ajk)
Thanks for the reply, one guy told me Honda calls for 185 psi as new on a stock B16a first gen. BTW... the ECU we purchased from you has worked flawless, and I've been telling everyone about your business.
Richie
Old Jan 27, 2003 | 10:36 AM
1SlowB16EF's Avatar
my b16 compression test results...
1-260
2-260
3-259
4-263
b16a971
Feb 20, 2016 11:46 PM
TylerH
Mar 15, 2006 11:16 AM
y_design
Jul 13, 2004 12:39 PM
civikdude
Mar 25, 2004 12:57 PM
Lysawy
Dec 8, 2003 11:04 PM
