Balancing rods
Old Jan 27, 2003 | 02:57 PM
McFly's Avatar
Default Balancing rods
To what tollerances do the connecting rods need to be balanced to? 1 gram, 0.1 gram, or 0.01 gram of each other? Thanks
Old Jan 27, 2003 | 07:10 PM
McFly's Avatar
Default Re: Balancing rods (UnderFire)
top
Old Jan 27, 2003 | 09:53 PM
1SlowB16EF's Avatar
as close as absutely possible!
Old Jan 27, 2003 | 10:26 PM
Nameless RB26's Avatar
Default Re: Balancing rods (1SlowB16EF)
good answer..
Old Jan 27, 2003 | 11:09 PM
Wynode's Avatar
Default Re: Balancing rods (Nameless)
Don't know if it helps, but ITR rods are balanced so well that the weight difference is neglible!
[Modified by Wynode, 8:09 AM 1/28/2003]
Old Jan 28, 2003 | 02:13 AM
evo's Avatar
evo
New User
Default Re: Balancing rods (Wynode)
Is it necessary to balance with the crankshaft?? I've only balanced the pistons and rods.
Old Jan 28, 2003 | 08:43 PM
vhd's Avatar
vhd
Default Re: Balancing rods (evo)
for the reciprocating end and total rod weight as well as the pistons, its good to have them within a gram of each other. no, inline engines like honda do not need bob-weights to be added to the crank when balancing, its only used when balancing a v6/v8 crank
[Modified by vhd, 9:43 PM 1/28/2003]
Old Jan 28, 2003 | 09:25 PM
sgT's Avatar
sgT
well, i disagree with that.
i've seen a few sets out as far as 5g
Old Jan 29, 2003 | 07:32 AM
EK Ferio's Avatar
Default Re: Balancing rods (sgT)
I'm so lucky that my rod weight difference are under 1g. Mine's are JDM 96spec engine.
Old Jan 29, 2003 | 08:11 AM
sgT's Avatar
sgT
Default Re: Balancing rods (EK Ferio)
imo yes
Old Jan 29, 2003 | 08:20 AM
CHEETAH's Avatar
wow, rods that came in the same motor ?
guys at the plant must have been sleeping that night ... thats careless especially when it came to those R motors.
greg
Old Jan 29, 2003 | 10:00 AM
sgT's Avatar
sgT
Default Re: Balancing rods (CHEETAH)
yep.
Old Jan 29, 2003 | 10:05 AM
Kataku2K3's Avatar
greg
That's why we assemble our motors... We are just waaaay more CAREFUL/PICKY then those ***** at Honda!!!! hehehe
Old Jan 29, 2003 | 04:13 PM
EK Ferio's Avatar
However, I found the weight difference of piston are more than 3g, one of the piston had 5g difference
Old Feb 2, 2003 | 08:29 AM
McFly's Avatar
The electronic scale I have is acurate to 1gram. This should be adequate for balancing right? Also, Where do you remove metal from a piston when balancing? Thanks
Old Feb 2, 2003 | 06:14 PM
McFly's Avatar
Old Feb 3, 2003 | 07:46 PM
McFly's Avatar
Old Feb 3, 2003 | 08:05 PM
IN VTEC's Avatar
Both local builders that I've talked to recommended taking it out of the inside/bottom of the piston....providing that there's enough material there to work with to drill out a few spots.
xQB21x
60
Dec 19, 2006 10:32 AM
b.d.racing
13
Dec 19, 2005 11:17 PM
ActiveAero
24
Jan 14, 2004 10:27 AM
Toretto
Dec 8, 2002 04:03 PM
importtuner
Jun 20, 2001 07:19 PM
