head milled to much !!!!!!!!!!!!!!!!!!1
Old Jan 25, 2003 | 03:29 PM
bstock1990's Avatar
Default head milled to much !!!!!!!!!!!!!!!!!!1
hey i picked up a B16 head on saturday with a portflow port job
the port work looks great but the head is been milled pretty bad you can no longer see the round chambers on the deck
my question is im afraid of getting it resurfaced because there are slight scratches from the head been pushed around the shop
i brought it to the machine shop and hopefully it can be saved ............
[Modified by bstock1990, 12:30 AM 1/26/2003]
Old Jan 25, 2003 | 04:24 PM
d15dood's Avatar
Default Re: head milled to much !!!!!!!!!!!!!!!!!!1 (bstock1990)
hope everything goes alright
Old Jan 25, 2003 | 10:44 PM
Unsung's Avatar
good luck... clay test before u start it up.
Old Jan 26, 2003 | 09:38 AM
non-VTEC's Avatar
why not call portflow them selves and ask them why the milled so much.......that doesnt sound to good.......
Old Jan 26, 2003 | 12:38 PM
BluntMan's Avatar
Call port flow! Now your belt could be to loose too!
Old Jan 26, 2003 | 07:06 PM
MAX_CFM's Avatar
Default Re: head milled to much !!!!!!!!!!!!!!!!!!1 (BluntMan)
its probally a GSR head DUH
Old Jan 27, 2003 | 12:24 AM
Dual Cams's Avatar
get it check to see how much is mill... you could run a thicker head gasket too on a pretty mill head. good luck
Old Jan 27, 2003 | 09:41 PM
dragonz04's Avatar
If you got the cash, I suggest a Cometic head gasket.
I also have a highly milled b16a2 head, I used the Cometic 60,000 works pretty good for me, but u should have it checked out to see how much your head was milled.
Project eg6 coupe: z/v-tec
d16z6EG
Aug 30, 2010 05:34 PM
Tigfab
Jun 3, 2007 03:04 PM
DC2SIR-G
Oct 17, 2005 01:54 PM
Andrew 825SM
Sep 30, 2002 02:54 PM
