D16Z6 with B16A1 pistons
Old Jan 27, 2003 | 12:59 AM
SOHC_DK.'s Avatar
Default D16Z6 with B16A1 pistons
How will this work, and is it worth the work, or is it better to buy JE-pistons?? I am doing only N/A, and the next investment will be Crower stage 2 cams.. Or a nother brand if you guys have any suggestions...
M. Nielsen, Denmark
Old Jan 27, 2003 | 01:11 AM
VTEC-DA's Avatar
Default Re: D16Z6 with B16A1 pistons (SOHC_DK.)
This is from Spade's SOHC upgrade thread.
The 1988-1989 D16A1 Engine came with some really high dome pistons. They cost around 30 dollars each from the Acura dealer as well, and will increase your compression ratio as follows:
d16a1 pistons (stock bore) in the following with a y8/z6 metal headgasket(no mill):
d16a6= 11.08: 1 compression
d16z6= 12.03: 1 compression
d16y8= 12.61: 1 compression
If you are going all motor and wanna keep it cheap (by wanting to use B16 pistons, it sounds like you do) this is defiantely the way to go.
[Modified by VTEC-DA, 5:12 AM 1/27/2003]
Old Jan 27, 2003 | 03:29 AM
Charlie Moua's Avatar
M. Nielsen, Denmark
Well the D16 has a bore of 75mm, where as the b16 has a bore of 81mm......
---so they only way you could do that is with a custom sleeved block(but even with a sleeved block i don't think it would be a good idea.
CAMS: try exospeed.
[Modified by Charlie Moua, 6:30 AM 1/27/2003]
Old Jan 27, 2003 | 03:36 AM
SOHC_DK.'s Avatar
Default Re: D16Z6 with B16A1 pistons (Charlie Moua)
well now I am confused.. what about the text Spade wrote.. It says that it's possible to use the B16A1 pistons.... but "CM" says they wont fit????
who's right???
M. Nielsen, Denmark
[Modified by SOHC_DK., 1:37 PM 1/27/2003]
Old Jan 27, 2003 | 05:50 AM
eg6ajk's Avatar
spade talked about D16A1 (dohc zc motor) pistons are P29 or in euro PM7 found in 88-91 civic ZC dohc.
Old Jan 27, 2003 | 10:32 AM
turbohf's Avatar
Default Re: D16Z6 with B16A1 pistons (VTEC-DA)
is this a stock head (or a A6 block with Z6 head)? an A6 with A1 pistons will have a 11.08:1 compression?
spens 91 Ef
21
Feb 26, 2009 06:37 PM
hondaboyB18C1
Dec 23, 2003 09:30 PM
hj
Oct 22, 2003 01:21 PM
xci_ed6
Aug 17, 2003 10:57 PM
