P13 vs P72, info requested
Old Jan 26, 2003 | 09:43 PM
CHK4TIX's Avatar
Default P13 vs P72, info requested
Ok, I cant find what i need to know by searching, so here goes. What do i have to change out to make a P72 work on a H22a both are OBD1. And i would like opinions of which is better between the P13 and the P72. Thanks
Old Jan 27, 2003 | 12:17 AM
CHK4TIX's Avatar
Default Re: P13 vs P72, info requested (CHK4TIX)
anyone?
Old Jan 27, 2003 | 12:26 AM
Dual Cams's Avatar
i personally like the p13. if both is OBD1 then it should just plug in and play
Old Jan 27, 2003 | 05:53 AM
eg6ajk's Avatar
Default Re: P13 vs P72, info requested (Dual Cams)
from testing both. the P13 (JDM with a spoon chip) vs the P72 with the XS program.
P13 seems to make much more HP/trq. throughtout the powerband. also no dip in @ vtec switchover.
p72 will just plug and work. but I would persoanlly go for a chipped JDM p13
Old Jan 27, 2003 | 07:22 AM
CHEETAH's Avatar
I usually reprogram the P72 to work the h22 motor, injector pulse stock over stock is different due t different injector sizes. Timing maps are slighltly different as well since the h22a does not like as much timing as a b18c
if you want a chip feel free to PM
greg
Old Jan 27, 2003 | 02:27 PM
CHK4TIX's Avatar
Default Re: P13 vs P72, info requested (CHEETAH)
thanks, guys...
SIckH22Atch
Nov 18, 2005 04:54 PM
fastest
Nov 10, 2004 06:10 PM
Nick M
Dec 10, 2003 05:55 PM
ArchAngel Sabastian
Nov 26, 2002 03:40 PM
joshuacast23
Nov 4, 2002 10:09 AM
