New Clutch
Old Jan 26, 2003 | 11:03 AM
steve_s's Avatar
Default New Clutch
If I get a new performance clutch for my stock 93' Civic EX replacing the stock clutch do I need any new additional components.
Someone told me that I would need a new flywheel because the old one wouldent be able to handle the new clutch.
Old Jan 26, 2003 | 11:18 AM
10K2HVN's Avatar
Default Re: New Clutch (steve_s)
nope..dont need*
Old Jan 26, 2003 | 11:21 AM
Hondasaurs's Avatar
You may want to consider having your flywheel resurfaced if you are getting a new clutch.
Old Jan 26, 2003 | 11:30 AM
ExospeedAMcrx's Avatar
Default Re: New Clutch (ZC_CRX)
no you dont need a new Flywheel. you do need to resurface it at least to clean it up and have a good contact patch for the new clutch disc. the flywheel gets worn out by the previous disc and can be warped or wear out unevenly. so get it resurfaced to provide a flat new surface for the new clutch kit.
if you want just a street upgrade from stock, check out ACTION clutch street upgrade kit on our website. its on the transmission section. that should be good enough for motors with just bolt ons. if you want to go turbo or go crazy all motor later on, i suggest stepping up to the 1md or 1mds to hold more HP.
SOHC_MShue
Oct 9, 2008 05:19 PM
rIceNOodles
Mar 12, 2007 03:05 AM
allmotor99lude
Jul 7, 2005 08:01 PM
BadEH2
Feb 19, 2005 02:42 PM
DriveSideWays
Feb 29, 2004 09:04 PM
