hid and projector??
Old Jan 27, 2003 | 03:19 PM
sslude's Avatar
Default hid and projector??
what are the differences between the two? i know that the projector is cheaper but i dont know why. and someone explain the differences? tahnks
Old Jan 27, 2003 | 04:55 PM
EBP_SI's Avatar
Default Re: hid and projector?? (sslude)
thats comparing oranges and apples.
you may want to compare:
projector vs. reflector
HID vs. regular halogen bulb
Old Jan 27, 2003 | 05:14 PM
sauceman's Avatar
Default Re: hid and projector?? (EBP_SI)
The projector is a type of sealed beam that you insert the bulb into, be it a halogen or an HID.
Old Jan 27, 2003 | 05:44 PM
sslude's Avatar
Default Re: hid and projector?? (sauceman)
okay, i am confused. can you explain hid by itself and projector by itself and halogen by itself. tahnks
Old Jan 27, 2003 | 05:45 PM
sslude's Avatar
and what is a reflector?
Old Jan 27, 2003 | 05:50 PM
tominos's Avatar
hid and halogen are the type of lights. hid stands for high intensity discharge. this requires ballasts and such to mount to your car, but the light output is amazing, runs at a much lower wattage. and lasts a long time. halogen, is the regular type of bulbs, that the factory puts in your car. the yellow collor in regular bulbs, indicates halogen bulb. projector is the type of headlight that umm, concentrates the light more i guess. i dunno how to explain it. if you've ever seen aftermarket projector headlights, this is just the type of headlight. most stock headlights use reflector type. hope that helps.
Old Jan 27, 2003 | 06:05 PM
sslude's Avatar
Default Re: hid and projector?? (tominos)
so HID is a light bulb or... and how does it appear to be changeing colors when drvivng?
Old Jan 27, 2003 | 06:07 PM
sauceman's Avatar
And to add to Tominos, maybe this link would help you to better understand how HID works. https://honda-tech.com/zerothread?id=391872
Old Jan 28, 2003 | 02:13 PM
sslude's Avatar
that link didnt help me.
white_horse
Lighting
27
Nov 26, 2011 02:12 PM
maal15
Dec 13, 2008 11:30 AM
ssm-gd3
Lighting
Sep 28, 2008 10:12 AM
viskii420
Lighting
25
Oct 31, 2007 04:21 PM
SilverDc2
Nov 26, 2002 10:06 PM
