b18a need your input!
Old Jan 26, 2003 | 12:24 PM
BluntMan's Avatar
Default b18a need your input!
Im helpin my friend build a b18a. using a fully P&P 2000 b18b head, crower stageIII cams etc. were lookin to get about 13:1 c/r. What are good rods a pistons to use with stock crank. Also looking for a real good r/s ratio, so might need raised wrist pins. so give me your input.
Old Jan 26, 2003 | 12:33 PM
BluntMan's Avatar
Default Re: b18a need your input! (BluntMan)
Anyone???????? ttt
Old Jan 26, 2003 | 03:48 PM
BudaKai's Avatar
For piston you might want to look here: theoldone.com
I wouldn't go with crower cams they have the reputation of snapping.
It all depends on how much you're willing to spend to what you should get.
Old Jan 26, 2003 | 03:59 PM
CRexcellence's Avatar
New User
theoldone.com (Endyne) sells rods and pistons, but they are stock configuration so you have the stock r/l ratio. If you want something different you are talking about custom stuff. I have seen a drag motor with a plate welded to the block that made the block higher. It used custom rods and I think stock configuration pistons.
Old Jan 26, 2003 | 06:19 PM
G2turbo_terror's Avatar
Default Re: b18a need your input! (jrx2002)
you talking about a decking? their good but a bit pricy and its best to have the plate welded too.
boostedbatch
Nov 14, 2010 12:17 AM
turbolscivic94
Jan 25, 2006 09:21 AM
butand50
Jan 23, 2006 04:03 PM
SwissChEz82
Mar 18, 2004 09:52 PM
crxsirvtec
10
Sep 6, 2003 09:38 AM
