GSR Vtec problem
Old Jan 27, 2003 | 09:01 PM
redhnda's Avatar
New User
Default GSR Vtec problem
94 gsr vtec don't work. "Anybody have any idea please help."
Old Jan 27, 2003 | 09:23 PM
Dan1krzysi's Avatar
Default Re: GSR Vtec problem (redhonda)
might be your oil is to low, check it and if so top it up.....
Old Jan 27, 2003 | 09:28 PM
StockTeg's Avatar
Engine not up to the right temperature is a possibility. Do you have a CEL?
Old Jan 27, 2003 | 09:32 PM
redhnda's Avatar
New User
Default Re: GSR Vtec problem (Dan1krzysi)
I try that, but I'll check again. The vtec was working, but after the car crash. "No damage to the motor". Vtec stop working.
Old Jan 27, 2003 | 09:42 PM
redhnda's Avatar
New User
Default Re: GSR Vtec problem (StockTeg)
I test the Vtec couple time before after driving it around for about an hour. Sometime check engine light come on then it went away by itself.
Old Jan 28, 2003 | 04:22 PM
Buckshot's Avatar
why do you keep putting everything in quotes...
since you got into a accident may a wire got knocked loose...but check your oil first.
Old Jan 28, 2003 | 06:53 PM
lazy bum shaughn's Avatar
Default Re: GSR Vtec problem (Buckshot)
I'm thinking the same thing. Are you throwing any CEL?
Old Jan 28, 2003 | 07:38 PM
jdlvl_type_R's Avatar
Default Re: GSR Vtec problem (lazy bum shaughn)
your V-tec wire probally got knock off or lose
Old Jan 28, 2003 | 09:06 PM
redhnda's Avatar
New User
Yes sometime CEL come on. After driving it for about an hours, and it went away by itself. I check the oil already, but I'll check on vtec wire.
Old Jan 29, 2003 | 05:45 AM
VTECVillain's Avatar
Jump the service connector under your dash and see what code it's throwing. One way to check if your VTEC Solenoid is working, disconnect the plug and apply 12V+ to the wire for the solenoid. If it's working correctly you'll hear it make a clicking noise.
Old Jan 29, 2003 | 09:20 AM
caLiH22A's Avatar
if you have a friend with a vtec engine ask to use there Vtec soleniod might be that you mest it up. or make sure of the wiring and oil before that. also a faulty ecu might do that also happend to a friend of mine.
Old Jan 29, 2003 | 09:27 PM
redhnda's Avatar
New User
Default Re: GSR Vtec problem (caLiH22A)
I am going to try a different vtec soleniod. A couple of people suggest that also. I check the oil already, and try a different ecu p28 . I have p72 chip but It ok. Thank.
[Modified by redhonda, 6:32 AM 1/30/2003]
Old Jan 30, 2003 | 06:50 AM
XLR8 GS-R's Avatar
Check your solenoid. Mine went out on my 98 gsr... Does it not let u rev past 5k? Like theres a limiter on there?? Thats what happend on mine
Old Jan 30, 2003 | 07:01 AM
bruthaboost's Avatar
What codes are you getting? Check your solenoid's resistance and continuity for your pressure switch.
Old Jan 31, 2003 | 09:56 PM
redhnda's Avatar
New User
Default Re: GSR Vtec problem (bruthaboost)
Didn't check for any code yet, but I'll be this week, and I'll try a different vtec soleniod from a friends car also. thank.
Old Jan 31, 2003 | 10:32 PM
kwil666's Avatar
start by cheching your codes and go from there.
keith
jdm.boi408
Nov 26, 2010 09:53 AM
gsrboost737
Aug 7, 2008 06:38 AM
tuckin15s_8315
Sep 28, 2005 10:12 PM
631 Teggy
16
Mar 10, 2004 10:28 AM
Worangejuice
Nov 15, 2003 06:36 PM
