knife edged crank.
Old Jan 27, 2003 | 07:47 PM
eg rookie's Avatar
Default knife edged crank.
just wanted to know on anyfeedback. what are the pro's and con's of knife edging
the crank. Is it worth it and any problems? driveability wise? thanks...
Old Jan 27, 2003 | 09:08 PM
Halo's Avatar
Default Re: knife edged crank. (eg rookie)
Your ability to rev up will be much more quick, but your idle will be screwed if too much material is removed, harmonics is your friend. Also no point in getting a knife edged crank if you do not compliment the lighter set-up with aftermarket rods and pistons
Old Jan 27, 2003 | 09:36 PM
1SlowB16EF's Avatar
there is no need for that... just have a reputable shop balance your rotation assembly... knife edging your crank is just you looking for problems... most PRO racers dont even use knife edged cranks in thier race cars ...and most deffinately not a good idea for a street car...bad idea
Old Jan 28, 2003 | 07:01 PM
eg rookie's Avatar
anybody else???
Old Jan 28, 2003 | 07:14 PM
eddiecut's Avatar
from honda they come good. why take the chance with a bad machinist messing up your whole motor.
Old Jan 28, 2003 | 07:50 PM
rioninja's Avatar
knife edging is an old musclecar trick, where the cranks would slosh through the oil in the crankcase causing aeration. On our hondas, the crank doesnt even come close to the oil in the pan. Not to mention that we have factory windage trays, to further isolate that problem.
IMO, knife edging is only to be considered if your looking to remove every last bit of weight. Not to be considered on a street car. If you want quicker revs, get a lightweight flywheel instead. IMO.
Old Jan 28, 2003 | 08:09 PM
CivicEK.PDX's Avatar
Default Re: knife edged crank. (Rioninja)
if you plan on taking your powerband higher then the stock rev limit then dont knife your crank.
Old Jan 28, 2003 | 10:06 PM
V3locity's Avatar
Default Re: knife edged crank. (efzero)
Good to hear, I was kinda wondering about knife edging anyway...
Old Jan 28, 2003 | 11:36 PM
Propulsion's Avatar
er ?
a unbalanced crank would result in more vibrations at high rpms.
Old Jan 29, 2003 | 12:58 AM
texan's Avatar
Well said.
Old Jan 29, 2003 | 04:56 PM
eg rookie's Avatar
thanks for all the input? I posted on other web sites, but nobody could tell me anything. I guess i'm just going to lighten and balence the bottom end. thanks.
Old Nov 9, 2009 | 02:43 PM
ZakUK's Avatar
just to bring this up
i have had my crank knife edged, they have calanced the whole bottom end too, but how does it affet the reliability at high RPM
they have made it more aero dynamic at higher RPM balanced to grade 6.3 iirc
Zak
greyEG
16
May 22, 2013 01:38 AM
95dcsleeper
Sep 5, 2005 06:48 PM
NERV
Sep 16, 2004 07:49 AM
Art701
Jun 24, 2003 06:22 AM
nwarp
Aug 2, 2002 10:44 AM
