dynamic compression questions
Old Jan 24, 2003 | 08:58 AM
-DC2-'s Avatar
Default dynamic compression questions
can the dynamic CR be calculated?
i am planning on pr3 pistons in my b18b1 and bumping the static CR up to 10.8-11:1, and i have mild regrind cams installed already. i say mild, cause i gained approx 10whp/wtq from them.
problem is, i don't know what the lift/duration specs are for the cams, and i don't want my dynamic CR to be too high once i install the pistons
thoughts?
here's fuel/ignition setup:
MSD ignition w/external coil
255lph walbro pump
91 octane
OEM 240cc injectors w/fuel pressure at 48-50psi at WOT
i will have adjustable cam gears and full p&p head/im/tb installed prior to dyno run for tuning w/wb o2
[Modified by DOHCDX, 6:03 PM 1/24/2003]
Old Jan 24, 2003 | 11:32 AM
lazerus's Avatar
Default Re: dynamic compression questions (DOHCDX)
"dynamic" as in on boost compression ratios? yes, they can be calculated.
11:1 Compression 6 lbs boost ~15.5 c/r
11:1 Compression 7 lbs boost ~ 16.3 c/r
11:1 Comrpession 8 lbs boost ~ 17.0 c/r
Etc etc...
Old Jan 24, 2003 | 11:43 AM
10K2HVN's Avatar
Default Re: dynamic compression questions (lazerus)
i cant see anything thats he said about boost....
..well anyways.. here ya go...but your gonna need those cams specs...
http://www.rbracing-rsr.com/comprAdvHD.htm
.(Lazarus).'s Avatar
I know it can be calculated but I'm not sure how. If you get the specs on the cams and talk to a really good head porter, they can probably help you out. The cam manufacturer can probably held you pick a CR too.
Old Jan 24, 2003 | 11:48 AM
-DC2-'s Avatar
Default Re: dynamic compression questions (ATXhybrid)
no, definitely NOT under boost
thanks for the link.
Old Jan 24, 2003 | 12:06 PM
10K2HVN's Avatar
:wink:
heres more:
http://www.team-integra.net/sections...?ArticleID=472
http://www.team-integra.net/forum/di...1&ThreadPage=1
Old Jan 24, 2003 | 12:08 PM
-DC2-'s Avatar
well, i don't know how accurate this is...
here's the results, i estimated 40deg for intake ABDC cause that yielded ~211psi for cranking pressure, which sounds about right. thing is, it said the dynamic CR would be 10:1 at my elevation
Old Jan 24, 2003 | 12:10 PM
-DC2-'s Avatar
yes, excellent info!!!!!
snaileg
Nov 8, 2006 04:11 PM
chriskona
Sep 25, 2006 07:34 AM
RooskiGSR
Feb 28, 2005 04:23 PM
7rrivera7
Apr 20, 2004 03:46 AM
7rrivera7
Oct 23, 2002 06:58 AM
