Problem checking CEL codes.. HELP!
Old Jan 24, 2003 | 03:39 PM
Soled Out's Avatar
Default Problem checking CEL codes.. HELP!
I've got a 1993 Civic cx w/a B16a II motor in it, and im having a problem with it redlining @ 3k rpms.
The CEL is on, so i tryed checking the codes. I found what appears to be the little blue plug that needs to be jumped in order for the CEL to flash, and i jumped it. I turned the key into the ON position, and the CEL doesnt flash! So i was thinking maybe that meant a code 0 and that the ecu was bad, so i plugged in the CX ecu, and the same thing happened. Is there any other way to jump the ecu so i can get the CEL to flash? I followed this write up http://www.c-speedracing.com/faq/06.php
What procedure do you use to check your OBD-1 CEL?
Old Jan 25, 2003 | 09:23 PM
salbaje's Avatar
Default Re: Problem checking CEL codes.. HELP! (Gray EG)
make sure that you are putting in the jumper wire correctly. then the cel light should blink
Old Jan 26, 2003 | 05:47 AM
Soled Out's Avatar
Default Re: Problem checking CEL codes.. HELP! (salbaje)
I made sure the wire was hitting the contacts on each side, but still no blink.
japek
Mar 19, 2010 08:34 PM
circapunk
Jun 7, 2009 09:32 AM
lv6l
Oct 27, 2005 04:01 PM
Pfieff
Aug 31, 2003 05:23 PM
Soled Out
Jan 23, 2003 06:59 PM
