Buffing tail lights ?
Old Jan 27, 2003 | 11:04 AM
RCautoworks's Avatar
Default Buffing tail lights ?
Can this be done ? I have my stock ones off and before I put them back on I wanted to know if I can buff them and make them shine again. And would I do it the same way I buff metal and everything else ? Thanks
[Modified by 90blackcrx, 2:15 PM 1/27/2003]
Old Jan 27, 2003 | 12:46 PM
Farnsrocket's Avatar
Default Re: Buffing tail lights ? (90blackcrx)
Get some 3M plastic polish
Old Jan 27, 2003 | 12:58 PM
Desslok's Avatar
Default Re: Buffing tail lights ? (Farnsrocket)
That and I believe it's Nexus (sp?) work good.
Old Jan 27, 2003 | 01:02 PM
qcoffey's Avatar
Default Re: Buffing tail lights ? (sp)
Both work well. The process is very similar to buffing a car, but you don't want to burn the plastic.
Old Jan 27, 2003 | 09:55 PM
Default Re: Buffing tail lights ? (qcoffey)
I just bought some columbian Tripoli compund. It saays for a bright, shiny luster to non ferrous metals, plastics wood and painted surfaces. Does this sound good ?
Old Jan 28, 2003 | 05:41 AM
pdxbrandon58's Avatar
I had old nasty taillights, so I sanded em with 1500 grit sandpaper, then sprayed clear auto paint with a splash of House of Color transparent candy apple red pigment to the clear. 2 coats later, they are shining like a ruby. The pigment is like 15 bucks. Polishing the factory ones with plastic polish works ok too.
[Modified by 90blackcrx, 2:15 PM 1/27/2003][/QUOTE]
Old Jan 28, 2003 | 06:11 AM
Desslok's Avatar
Tripoli works good with a power buffer. It's a little harsh for plastic, you can easily burn melt pastic. I use Tripoli mostly for gold. Try it on an old piece from a junkyard or something first.
EK9Tune
36
Sep 2, 2006 08:23 PM
b16rex_02
Aug 17, 2006 08:25 AM
keeblerdog8
Aug 15, 2005 09:17 AM
xstalkrx
Apr 20, 2003 07:28 PM
Eggman
Mar 2, 2003 05:19 PM
