vtec controller problems
Old Jan 24, 2003 | 03:46 PM
b18bEG's Avatar
Default vtec controller problems
ok so ive had my vtec controller for a while now, and no problems. last night i went to change some settings, everythying was cool, and then turned off my car. when i went to turn it on again, everythign was re-set. and yes, i initialized it and everything too. any body know what the problem is?
Old Jan 24, 2003 | 04:20 PM
FitCRX's Avatar
Default Re: vtec controller problems (h22akrd)
I would guess that it isn't associated with the controller. After it was initialized did you set everything back...4cy...up down arrows...even tho I don't think that would stop the car from starting. good luck
Old Jan 24, 2003 | 04:25 PM
b18bEG's Avatar
Default Re: vtec controller problems (FitCRX)
no no, may car didnt turn off, the vtec controller re-set to vactory settigns, meaning all my fuel setting and all were lost. the car itself is fine
Old Jan 24, 2003 | 04:37 PM
FitCRX's Avatar
So all you settings where lost... when you intilize it...under
"ETC Modes" > "Initialize" it re-sets everything. If you didn't select that, then the control must have lost power somehow...battery, or lose power wire.
Old Jan 24, 2003 | 07:54 PM
sslude's Avatar
is that becuase of the damn OBDll thing? that it "detects" the changes made to your car and sets them back? try doing the OBDll workaound at http://www.ntpog.org
Old Jan 28, 2003 | 04:56 PM
b18bEG's Avatar
Default Re: vtec controller problems (sslude)
yah i understood everything wrong on the manual, i thought that when you hit initialize, it saved everything, but i was being a non reading ***. its fixed now. thanks for all the info fellas
lifes_simple
Oct 6, 2010 02:25 PM
A.R
Sep 23, 2009 04:59 PM
Los.
Dec 24, 2004 11:25 PM
