ACT Clutches??
Old Jan 25, 2003 | 12:04 PM
genetsang's Avatar
Default ACT Clutches??
is it TRUE that ACT Clutches are OEM/Stock???? i was informed, all ACT does is grind away the OEM/stock logo and #, then repaint it yellow and restamp it with the "ACT"....... that was what i told by my mechanic.... i didnt believe them on what they had told me.. but then they later showed me an ACT clutch for which it had happened.... and said most CLUTCH companies does that, except CENTERforce
Old Jan 25, 2003 | 12:20 PM
Malgerus's Avatar
Default Re: ACT Clutches?? (genetsang)
There are 3 stages to choose from. The first stage is stock. The second stage is "modified" I just bought one, along with the heavy duty pressure plate, and it sure doesn't look stock to me!
Old Jan 25, 2003 | 12:29 PM
genetsang's Avatar
Default Re: ACT Clutches?? (Mr. S)
i dont have a dam clue.. b/c the mechanic told me that ACT clutches are OEM, and all ACT does is..... grind out the OEM logo and restamp it with "ACT"..... and resells it as ACT.....
Old Jan 25, 2003 | 01:07 PM
lazy bum shaughn's Avatar
That would suck if it was true.
Old Jan 25, 2003 | 03:27 PM
B20Monster's Avatar
Default Re: ACT Clutches?? (lazy bum shaughn)
hmm..i havent felt any oem clutches grab as hard as the ACT... i have a ACT 6 puck and full face for my 1st gen b16. feels totally different from oem.. and the pedal pressure pushes my leg back out.!
Old Jan 25, 2003 | 05:06 PM
AzG35's Avatar
Default Re: ACT Clutches?? (B20Monster)
I highly doubt this. Act pressure plates are much firmer in the pedal than ANY stock clutch. Plus, even a ITR clutch will slip under substantial power, ACT's will hold up to much more power than any stock clutch. Plus, they have a warranty as well.
Old Jan 25, 2003 | 05:20 PM
Kamin's Avatar
that is not true
your mechanic is a retard
i dont think you should take your car back to him.
Old Jan 25, 2003 | 06:58 PM
10K2HVN's Avatar
Default Re: ACT Clutches?? (Kamin)
that is not true
ditto!
ACT use* to take OEM pressure plates (pp) rip off the old and add the own diaphrams to them to make them stiffer...it worked well enough to give them a good name for hondas but not as well as their new 100% ACT pp's...
Old Jan 25, 2003 | 07:06 PM
genetsang's Avatar
Default Re: ACT Clutches?? (10K2HVN)
so it is true???? so the shop that i went to wasnt trying to screw me.... my boy is there getting his clutch changed.... (its a vdubb) but still clutch is a clutch.. and the shop told him to stick with the SACHS clutch (which is the oem vw clutch) which they say is the same clutch that ACT offers for his car.......
Old Jan 25, 2003 | 07:16 PM
10K2HVN's Avatar
OMG!!! NO ITS NOT THE OEM CLUTCH!!! There stage 1 maybe close to OEM spec but its still sronger!!! gesh!!@
Old Jan 25, 2003 | 09:03 PM
SmoothVTEC's Avatar
Come on dude...how the hell do you think they could saty in business if they did that? I mean damn, your mechanic is a moron. If he believes this truly, tell him this:
I have a great way for him to make EASY money. Just go buy a bunch of Honda Civics and replace the "HONDA" and "CIVIC" emblems with "RETARD MECHANIC" emblems then he has his own brand of car.
I wouldn't take my car back to him if he talks nonsense like that.
Old Jan 26, 2003 | 07:35 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: ACT Clutches?? (SmoothVTEC)
BULLSHIT
beanbag
Jan 9, 2008 04:09 PM
Francesco
Honda S2000
13
Oct 26, 2006 12:22 PM
TAG
16
May 16, 2005 03:29 PM
sohcvtec1995
14
Feb 23, 2005 07:56 PM
