How do I know if the distributor is sparking on exhaust instead of compression?
Old Jan 27, 2003 | 11:54 AM
T_Rex's Avatar
Default How do I know if the distributor is sparking on exhaust instead of compression?
(fixhondas)
The shaft in your distributor is round, with the screw removed the rotor can turn freely on the shaft. The hole for the screw sometimes is drilled all the way through the shaft. When the hole is all the way through the shaft you can remove the screw, rotate the rotor on the shaft 180 degrees and reinstall the screw- then you will be sparking on exhaust instead of compression. This is just to let you know it is possible.
This is from an IM from fixhondas. I'm worried I may have mounted the rotor wrong because I've already burned up one cap and coil...but I don't know how to check if it's on the right way? Any help is greatly appreciated
[Modified by T~Rex, 1:31 PM 1/27/2003]
Old Jan 27, 2003 | 12:01 PM
Nameless RB26's Avatar
Default Re: How do I know if the distributor is sparking on exhaust instead of compression? (T~Rex)
What made you play with the timing anyways?
Old Jan 27, 2003 | 12:03 PM
T_Rex's Avatar
Default Re: How do I know if the distributor is sparking on exhaust instead of compression? (Nameless)
I didn't...just had to change out the cap and rotor.
Old Jan 27, 2003 | 12:04 PM
IN VTEC's Avatar
The only way you could reverse the ignition timing is if you removed the pin from the intake cam interface side and flipped the keyway around. This is probably what the fixhondas guy was referring to...just using mixed terminology.
The rotor side of the distributor is fixed...the rotor only goes on one way.
Old Jan 27, 2003 | 12:05 PM
Desslok's Avatar
Put #1 cylinder at TDC, and check the cam gear to see if the top mark points up, then the rotor should be pointing at the #1 plug on the distributor cap.
Old Jan 27, 2003 | 12:07 PM
T_Rex's Avatar
Default Re: How do I know if the distributor is sparking on exhaust instead of compression? (IN VTEC)
Thanks for the reply, but when I re-read the quote from fixhondas, it's clear to me that he's talking about the distributor shaft. He says that since the hole is all the way through the shaft, the rotor can be mounted one way, or if you turn it 180 degrees, it can go that way. I need to know which way is correct?
Old Jan 27, 2003 | 12:10 PM
T_Rex's Avatar
I should point out that the title should read:
How do I know if the distributor <U>ROTOR</U> is sparking on exhaust instead of compression.
Also, what's TDC?
[Modified by T~Rex, 1:13 PM 1/27/2003]
-Whitey-'s Avatar
look at my reply in the eg forum
Old Jan 27, 2003 | 12:26 PM
IN VTEC's Avatar
With the distributor rotor facing the #1 cylinder position (bottom left corner), the side of the keyway with the asymmetrical index mark should be facing the back side of the distributor (back of the engine/car).
Visual reference is from the passenger-side fender looking at the distributor mounted on the engine.
I'll take a quick pic.
Old Jan 27, 2003 | 12:33 PM
T_Rex's Avatar
Thanks
Old Jan 27, 2003 | 12:37 PM
IN VTEC's Avatar
Old Jan 27, 2003 | 01:43 PM
Lord Helmet's Avatar
helms rule
azzurribaggio
Jun 26, 2009 09:25 PM
azzurribaggio
Jun 26, 2009 05:07 PM
ice11honda
May 14, 2005 05:47 AM
piggypen
Feb 22, 2005 11:11 PM
T_Rex
Jan 27, 2003 12:38 PM
