Sizzle???
Old Jan 24, 2003 | 01:09 PM
XxDemonxX's Avatar
Default Sizzle???
i got home today and i just decided to look under my hood..it was rather warm. So i then dripped some water on my header and it like sizzled. I know engines do heat up quite a bit but is this normal? what is the best way to keep your engine cool?
Old Jan 24, 2003 | 01:27 PM
10K2HVN's Avatar
Default Re: Sizzle??? (XxDemonxX)
H-Ters told me to run a higher water to coolent ratio...
Old Jan 24, 2003 | 01:28 PM
steve_s's Avatar
Engines get very very hot.
Yes it should sizzle, just make sure your radiator is in good shape and u got good coolant and youll be set.
Old Jan 24, 2003 | 01:43 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Sizzle??? (steve_s)
Umm, of course it's going to sizzle. Your exhaust gases are approaching 1600 degrees sometimes. It gets damn hot under there, just don't touch it.
As long as your cooling system is fine, you're good to go.
Old Jan 24, 2003 | 01:46 PM
Desslok's Avatar
Default Re: Sizzle??? (shamoo)
I have a permanent scar on my arm from my skin sizzling against my header.
Old Jan 24, 2003 | 01:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Sizzle??? (sp)
Yes.......lol that's a good one. Your engine gets hot. Now try laying on it. IT's a good warmer.
Old Jan 24, 2003 | 02:45 PM
sslude's Avatar
Default Re: Sizzle??? (HybridcivicLS-T)
well think about it. exhuast is burnt fuel, its most likely going to be hot. mabye get some heat wrap, and thats about all i can think of.
Old Jan 25, 2003 | 10:39 AM
XxDemonxX's Avatar
Default Re: Sizzle??? (sslude)
is it good when your done to put a fan on it. Ive seen some dyno testing and they have like 3 fans going at them...Is this a good idea or does it even matter?
Old Jan 25, 2003 | 11:05 AM
Phoenix_ITR's Avatar
what mods to you have on your car to warrant a cooling fan after you drive? dynos have fans blowing air through the radiator because the car is being redlined while it is stationary -- i.e. : there is no air flowing over the car otherwise. if you're really worried about it, you could always wire a switch to your stock radiator fans so that you can turn them on/off.
-tony
Old Jan 25, 2003 | 12:19 PM
Malgerus's Avatar
I wouldn't get header wrap... it's not good for street driven cars, because the header can rot out faster. Just make sure that your cooling system is in good shape... if you think you're running too hot go buy a colder thermostat. If you're still running too hot consider upgrading your radiator.
Honda_HUN
27
May 20, 2019 05:24 PM
raider1qaz
Feb 17, 2013 01:52 PM
b16a4
Nov 6, 2007 11:17 AM
bread
Jul 5, 2004 01:39 PM
Mojo-Jojo
Apr 2, 2003 06:57 AM
