Hydro vs Cable What's the difference and which is better???
Old Jan 24, 2003 | 05:58 PM
crxguy05si's Avatar
Default Hydro vs Cable What's the difference and which is better???
What is the difference between a hydro trani and a cable trani?which one is better??
[Modified by crxguy05si, 10:02 PM 1/24/2003]
Old Jan 24, 2003 | 06:46 PM
Propulsion's Avatar
Default Re: Hydro vs Cable What's the difference and which is better??? (crxguy05si)
cable is operated by pulling a metal cable (like throttle cable)
hydro is operated by hydrolic pressure (like brake lines)
hydrolic is smoother, which is why newer cars have them now.
Old Jan 24, 2003 | 07:25 PM
Colin's Avatar
personally I like the feel of a cable tranny a little more.
assuming you have a crx (cause of your name), i'd just stick with the cable tranny setup. Converting over to hydro would be a lot of work, more $$, and the benefit (if any) is minimal.
Old Jan 24, 2003 | 07:35 PM
sslude's Avatar
Default Re: Hydro vs Cable What's the difference and which is better??? (91IntegGS)
so, how would i be able to tell if it was a hydro tranny or a cable tranny from in side the car? are the shifts smoother?
Old Jan 24, 2003 | 07:40 PM
Turbo Lude SH's Avatar
Default Re: Hydro vs Cable What's the difference and which is better??? (sslude)
Pop the hood and see if the clutch is being actuated by a cable or a hydraulic line. It's pretty easy to tell.
lilo_goki
Apr 20, 2007 11:25 PM
wetbak
Sep 12, 2005 10:45 PM
1TwistedEG
Mar 18, 2005 07:28 AM
ldanphanl
Mar 6, 2005 08:50 PM
joey1320
Feb 20, 2003 01:19 PM
