What tool do i need for fuel filter?
Old Jan 26, 2003 | 05:44 AM
. o 69 o .'s Avatar
Default What tool do i need for fuel filter?
I need to buy some tools for working on my car, what do i need to change the fuel filter? Line wrenches?open end? box end? and sizes in mm/inches
Old Jan 26, 2003 | 07:57 AM
tilt's Avatar
Default Re: What tool do i need for fuel filter? (B16B)
There is a banjo bolt that is either 10 or 12mm. And you will need 2, 14 or 17mm open ended wrenches for the fuel filter... one to unbolt and the other to hold the filter.
Honda/acura loves to use metrics 8, 10, 12, 14, 17, 19, 32 so get a metric toolbox set.
Old Jan 26, 2003 | 08:07 AM
integra6650's Avatar
Default Re: What tool do i need for fuel filter? (tilt)
you dont see too many 8s but definately go to sears and get a metric set
combo wrenches 50 bucks for sizes 8-20
[Modified by integra6650, 12:08 PM 1/26/2003]
Old Jan 26, 2003 | 10:06 AM
Pat's Avatar
Pat
Default Re: What tool do i need for fuel filter? (integra6650)
I recommend using flare nut wrenches as opposed to open end, for this particular case.
Old Jan 26, 2003 | 04:00 PM
. o 69 o .'s Avatar
Default Re: What tool do i need for fuel filter? (Pat)
flare nut wrenches ... how much are they?
Old Jan 26, 2003 | 08:09 PM
26 for sizes 10-17 or maybe 18 at craftsman
Old Feb 1, 2003 | 09:32 PM
. o 69 o .'s Avatar
ok.. i did the filter today, and these are the tools necessary for this procedure:
-10 mm socket
-13 mm socket
-17 mm wrench
-19 mm wrench
-9/16 or 14 mm line wrench
It took me about 3/4 of an hour to do everything. I found it easier to get at the filter after i removed the intake pipe. Also, crack all the fittings before you remover the assembly from the fire wall... its very easy to bend the fuel line on the bottom. Otherwise, very easy to do, no busted knuckles, and swearing necessary.
[Modified by B16B, 10:33 PM 2/1/2003]
Old Feb 1, 2003 | 10:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Correct, you dont want to use the open ended wrenches for the fuel filter. Snap on calls these wrenches line wrenches if Im not mistaken.
art
Randomnoob
Jan 4, 2019 03:20 PM
sc34dc4
Oct 29, 2011 12:09 PM
2kstreetcivic
Jan 18, 2005 07:42 PM
Ti3d in
Jul 27, 2004 07:57 PM
AK94GSR
Aug 7, 2002 08:02 PM
