IACV...control first gear idle???
Old Feb 24, 2003 | 12:13 PM
made in JAPAN's Avatar
Default IACV...control first gear idle???
i recently swapped an LS/VTEC into my DA with lightened flywheel and stage 3 clutch. when starting out slowly in first gear, such as in a parking lot is almost impossible becauewhen youlet the clutch out a little bit the rpms drop down to like 500, and the car bucks, making it look like i have no idea how to drive standard. my question is, will cleaning the IACV help solve this problem????
Old Feb 24, 2003 | 12:42 PM
Perfectionist's Avatar
Default Re: IACV...control first gear idle??? (made in JAPAN)
The ECU controls the idle. Once you apply throttle, the idle circuit is no longer active. I would look into a mis-adjusted TPS, etc.
cstone
Jan 17, 2011 07:42 PM
97ekjdm
Sep 21, 2006 04:23 PM
93c1sol
Apr 23, 2006 08:31 PM
lude98SH
Dec 16, 2005 01:37 PM
