does the knock sensor give out voltage at idle?
Old Feb 23, 2003 | 02:04 PM
Rob Dizzle's Avatar
Default does the knock sensor give out voltage at idle?
My ecu keeps throwing a code for the knock sensor.
i have already swapped in a brand new acura one. and i still get a code.
i measured the voltage of the wire today. and i did not get any voltage that i could measure with my volt-meter.
any ideas?
i can run a new wire, i just want to make sure it will actually fix the problem
Old Feb 23, 2003 | 07:23 PM
Rob Dizzle's Avatar
Default Re: does the knock sensor give out voltage at idle? (Bob-DC2)
hello?
Old Feb 23, 2003 | 08:38 PM
baonest1's Avatar
hope this helps
try to save and zoom in.. ill see if i can make a bigger pic
[Modified by baonest, 12:38 AM 2/24/2003]
Old Feb 23, 2003 | 08:45 PM
tinkerbell's Avatar
hi Bob,
AFAIK,
the KS is a piezo electric device that detects the 'ping' or knock.
it sends a impulse to the ECU when it 'hears' a ping or 'knock'
ie it is a electro/mechanical type sensor. it has no voltage.
the wire needs to be 'shielded' ie with a sheath around it to protect from interference from other sound sources in the engine bay.
i hope this helps some...
t..
Old Feb 23, 2003 | 11:03 PM
Rob Dizzle's Avatar
Default Re: does the knock sensor give out voltage at idle? (tinkerbell)
yeha, i have the helms manual.
i have already heard that the knock sensor only sends a signal when it senses knock.
this thing sux
Old Feb 24, 2003 | 05:49 AM
Russ713's Avatar
dAng!
you're not the only one that has to deal with a knock sensor throwing a code. I just overcome it by drowning the gas tank with octane booster. No more codes til the octane point level drops back down .
Old Feb 24, 2003 | 09:12 AM
Rob Dizzle's Avatar
Default Re: does the knock sensor give out voltage at idle? (Black Light)
i wonder if my jdm itr pistons and itr cams with gsr head (11.4cr) is causing knock on cali 91 octane.
it doesnt seem like it knocks (i have never heard it on my car)
i filled up some 100 octane @ the 76 station. same problems though
ek4 sir civic
Jun 23, 2007 06:02 PM
tc_gts
11
May 4, 2005 05:26 AM
ddong2lee
Mar 4, 2004 05:06 AM
EF_LSVtec
Apr 10, 2003 11:25 AM
speshuled619
Jul 25, 2002 05:12 PM
