ARP rod bolts???
Old Feb 22, 2003 | 07:06 PM
InevitableRace's Avatar
Default ARP rod bolts???
What is the max RPM on ARP rod bolts on ITR rods???????
Thanks
Ross
Old Feb 22, 2003 | 08:27 PM
sgT's Avatar
sgT
Default Re: ARP rod bolts??? (allmotrb18c1)
should be just as good as the stock b18c rod bolts.
stock b18c bolts work fine.
Old Feb 22, 2003 | 08:58 PM
qtiger's Avatar
Default Re: ARP rod bolts??? (sgT)
Anything your head can handle. A properly balanced bottom end will not limit your RPMs. Something lighter than ITR rods would be better.
For the $30 investment required I would take ARP in a heartbeat.
Old Feb 22, 2003 | 09:23 PM
sgT's Avatar
sgT
Default Re: ARP rod bolts??? (qtiger)
30 + cost to recondition the rods once you install them.
I would only use them with non vtec rods.
Old Feb 22, 2003 | 10:24 PM
So what do you think?A stock ITR goes to 8500...Do you think the ARPs are a little better and they can handle 9000??
Now it has good side rod clearence and balanced and polished crank...and reconditions rods and ARP rod bolts...Do you think its ok to goto 9000k sometimes??Thats my question....
Thanks
Ross
Old Feb 23, 2003 | 12:39 AM
smokey2.0's Avatar
I would only use them with non vtec rods.[/QUOTE]
what do you mean to recondition the rods? can you explain this?
Old Feb 23, 2003 | 12:59 AM
sporkcrx's Avatar
Default Re: ARP rod bolts??? (smokey2.0)
Know of a website that sells those?
Old Feb 23, 2003 | 06:59 AM
PhatOptimo's Avatar
ITR rods with ARP bolts can handle 9000 rpm easily. I 'd bet they could take 10K. I have them on my B16a rods and have hit well over 9K with no adverse effects. You will need the 9mm arp rod bolts. I believe I paid 50 for the bolts and 20 to install them.
Old Feb 23, 2003 | 05:29 PM
delslow94's Avatar
when installing the bolts you have to press them in. when doing so the rod bearing area sometimes doesnt stay perfectly tru and distorts some. so you have to machine it to make it perfect again, this way you dont have bearing fitting problems or damage to the crank/rods/bearings/whatever in the future.
Old Feb 23, 2003 | 07:11 PM
tinkerbell's Avatar
Default Re: ARP rod bolts??? (delslow94)
called "re-sizing the big ends" or similar...
t..
Old Feb 23, 2003 | 10:08 PM
advanracing62's Avatar
Default Re: ARP rod bolts??? (tinkerbell)
I've got a stock B16 bottom and rev to 9k every time I drive the car... been that way over a year and no boom!
Jordb22
Jan 31, 2012 08:37 PM
roudiiboii
Nov 19, 2010 12:57 PM
blackccoupe
Sep 26, 2009 01:24 PM
neyrod
Feb 16, 2005 11:05 AM
b16supertuner
Dec 15, 2003 05:21 AM
