Will 2nd gen B16 distributor work on 1st gen B16?
Re: Will 2nd gen B16 distributor work on 1st gen B16? (fOmaNPu)
it'll work. if you are obd1. i think. all that matters is odb0 odb1 and odb2 distros. u gotta match it to teh ecu.
Re: Will 2nd gen B16 distributor work on 1st gen B16? (escocrx)
you cant use an obd 1 or 2 distributor with a pre obd computer... because of the sensors.
Re: Will 2nd gen B16 distributor work on 1st gen B16? (vtecdoc)
obd 1 &2 are interchangable but needs 2 be rewired, obd0 can only use an obd0 distrib. the answer to your qesion is no, unless u swap to an obd1 ecu.
Will be using a p28 ecu with a 1st gen B16 head and a b20 block. So I can use an OBD1 or 2 dizzy for this setup?
