Using excel to calculate tq from hp and mph?
Old Feb 24, 2003 | 11:33 AM
Junglist's Avatar
Default Using excel to calculate tq from hp and mph?
I have a graph like this:
I've heard that you can make a table in excel and use a formula to calc the tq into a graph. Anyone know how to do this???
thanks,
b
Old Feb 24, 2003 | 01:58 PM
JimBlake's Avatar
Default Re: Using excel to calculate tq from hp and mph? (Junglist)
Torque = ( HP / RPM ) * 5252
That gives torque in lbf-ft. Trouble is, you (probably) don't know the engine RPM at any given road speed. You could look for specifications (rpm/mph) for the M3, & guess which gear the M3 was in during that test... unless the M3 had an automatic tranny.
Old Feb 24, 2003 | 02:04 PM
keebler65's Avatar
Default Re: Using excel to calculate tq from hp and mph? (JimBlake)
if you own the car, you could drive it in the gear used, hold it at a constant speed, and look at the tachometer. then use the mph and rpms to find a multiplier.
Old Feb 24, 2003 | 02:12 PM
e36s52's Avatar
that's prolly a third gear pull. diff is 3.23:1 for '96-99 and '95 LTW ('95 was 3.15:1 otherwise), third gear is 1.66:1. rear tires are 245-40-17 for '96-99 and 235-40-17 for all '95.
using this info and the torque to hp conversion provided above, you can create a torque vs. rpm plot.
Dudeliness
Mar 15, 2008 05:58 PM
gsr-HF
Dec 26, 2003 10:48 PM
cr-x si
Nov 20, 2002 07:17 PM
Superhatch
Jul 10, 2002 04:29 AM
ActiveAero
Jan 18, 2002 04:03 AM
