#43 code on a delsol b16a3 with ausdm p30 ecu
Old Feb 24, 2003 | 11:15 AM
yellow eg's Avatar
Default #43 code on a delsol b16a3 with ausdm p30 ecu
pls I need some help , the chk eng light comes on when engine worms up every singel time. What is it and what do i have to fix.
Old Feb 24, 2003 | 11:18 AM
yellow eg's Avatar
Default Re: #43 code on a delsol b16a3 with ausdm p30 ecu (yellow eg)
Del Sol 93-95 Fuel Supply System
defective or malfunctioning fuel supply system
this is what i found out , .... dose this mean fuel pump or presure regulator????
Old Feb 26, 2003 | 10:57 AM
yellow eg's Avatar
pls i need some help
Old Feb 26, 2003 | 12:35 PM
Katman's Avatar
have you unplugged anything fuel related lately? or tampered with anything on your engine at all? if so, what did you tamper with?
Old Feb 26, 2003 | 07:02 PM
yellow eg's Avatar
Default Re: #43 code on a delsol b16a3 with ausdm p30 ecu (Katman)
nothing at all, that is the wierd thing , usualy it is me that coses stuff.....
Old Feb 27, 2003 | 09:12 AM
Katman's Avatar
hrm weird..
check to see that your ground wires are firmly bolted down. sometimes when the ground wire is loose or not even there you'll get weir unexplainable problems with your car.
Old Feb 27, 2003 | 09:28 AM
yellow eg's Avatar
the ground wire mount that comes of the motor and bolts on to the chasi? i unsed the mont on the chasi to ground the foglights too, would that influence it?..now tht i think bout it , it sounds stupid...
wierd thing!!! i swaped with a friend that has a jdm p30 chiped by muben in japan, it came like that from japan, mycar ran fine and no check engine light , and his got th same code on ajdm b16 sir2 and the nasty idle too.
ths katman
[Modified by yellow eg, 6:31 PM 2/27/2003]
SsB_Db8
Jul 14, 2007 11:25 PM
neuerasd9
Feb 16, 2006 01:58 PM
Leviata-N
Oct 8, 2004 07:01 AM
Motorvated
Jan 3, 2004 10:38 PM
NICHRIS143
Oct 28, 2002 09:09 PM
