ShiftLight Problem? Premature lightculation.
Old Feb 22, 2003 | 07:34 PM
cpforyou's Avatar
Default ShiftLight Problem? Premature lightculation.
I have a stock EG Honda Civic EX w/ stock motor and basic bolt-ons.
I have an AutoMeter Shiftlight w/ a 7.2K Pill.
Everytime I hit 7200RPM, the shiftlight turns always turns on as it should.
However, there are random instances when I just floor it, the shiftlight will flash on anywhere from 4000rpm - 6000rpm, and then it'll turn on at 7200RPM again like it usually should.
Any reason why the shiftlight might flash once randomly under hard acceleration?
Old Feb 22, 2003 | 08:26 PM
dfoxengr's Avatar
Default Re: ShiftLight Problem? Premature lightculation. (cpforyou)
if it runs off the distributor, then it could be that its overloaded when theres a quick increase maybe, ??hmm..also check grounds, lol
Old Feb 22, 2003 | 09:13 PM
cpforyou's Avatar
Default Re: ShiftLight Problem? Premature lightculation. (hybridvteceg)
Yeah, it runs straight off the distributor. The ground is a small bolt on the inside of my car under the steering wheel. That may be the problem....
Old Feb 23, 2003 | 10:47 AM
cpforyou's Avatar
*bump* I checked the ground, it's working fine. It runs straight off the distributor, the positive is running from the fuse box, and the ground is on a solid bolt on the chasis.
Dnelle95
11
Sep 23, 2011 08:36 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
mini-v-si
Mar 17, 2004 06:29 AM
toooslow
May 31, 2003 08:49 PM
Cashis EG8
Apr 28, 2003 04:33 AM
