Rear Main Seal question
Old Feb 23, 2003 | 06:33 AM
SI DOHC ZC's Avatar
Default Rear Main Seal question
im going to do the rear main seal tomorrow on my dohc zc motor but im not 100% sure yet whats involved. i know i have to take my tranny, clutch, flywheel, and oil pan off but my chiltons manual isnt very detailed on how to change the seal. if anyone has done a rear main seal on a honda motor PLEASE give me some insite. thanks a lot
Old Feb 23, 2003 | 06:50 AM
PhatOptimo's Avatar
Default Re: Rear Main Seal question (SI DOHC ZC)
Once you gain access to the rear seal remove the plate that holds the seal . I use a flathead screwdriver and a hammer to remove the old seal. It is fairly simple. When using this method you must be careful not to gouge the metal plate with the screwdriver. One one side breaks loose you can pull the old seal out. Installing the seal I use a piece of wood to drive the new seal in. Pretty simple. Take you time and all will go well.
Old Feb 23, 2003 | 07:27 AM
SI DOHC ZC's Avatar
that does sound pretty simple. thanks man
92lxsleeper
Jan 19, 2011 10:35 AM
rogue420
14
Jul 18, 2010 05:44 PM
Fatty_1775
Aug 23, 2006 03:23 AM
nos96f22
Apr 23, 2003 02:33 PM
Jesse H
Aug 12, 2002 09:05 AM
