HELP!!! cant get timing belt on?
Old Feb 25, 2003 | 12:30 AM
infamousALLMTR's Avatar
Default HELP!!! cant get timing belt on?
I am using a gsr timing belt, b16 head and b16 waterpump and the timing belt does not even look close to fitting and this is with the ls tensioner all the way down/loose. Is the ls belt longer than a gsr belt? Any ideas on how to get the belt on with out ******* the timing belt up?
confused
mike
Old Feb 25, 2003 | 03:39 AM
sgT's Avatar
sgT
Default Re: HELP!!! cant get timing belt on? (infamousLSVTEC)
the ls belt is shorter than the gsr belt.
how are you trying to put it on?
Old Feb 25, 2003 | 09:39 AM
Kataku2K3's Avatar
Default Re: HELP!!! cant get timing belt on? (sgT)
If the tensioner is loose then you should have no problem putting that t-belt on just so long as you have it routed correctly... Good Luck
Old Feb 25, 2003 | 11:52 AM
ionic_slim's Avatar
confused
mike
If you're using a b16 water pump...shouldn't you be using a b16 timing belt? If you're using a gsr water pump you could get the belt to fit.
Old Feb 25, 2003 | 02:58 PM
Kataku2K3's Avatar
Default Re: HELP!!! cant get timing belt on? (tazmoe)
All VTEC water pumps are the same... (22 teeth) nonVTEC is the exception and is different (17 teeth)... The B18C t-belt is what you would use on an LSVTEC with a VTEC water pump... Peace
Old Feb 25, 2003 | 07:16 PM
Default Re: HELP!!! cant get timing belt on? (Kataku2K3)
ok so schucks can lick a nut... they gave me belt part no. 95227 when I needed 95227 they could not even find what belt I had... with the gsr belt it went on with no problems.
thanks for all the info anyways
mike
made in JAPAN
Feb 22, 2011 05:29 AM
one8toh8
Jun 8, 2005 07:34 AM
TwoK4drSi
Aug 11, 2004 11:17 AM
playboyace35
Jun 25, 2004 12:14 AM
